rear wheel refitting how ?
sidewinder
PostPosted: 20:36 - 08 Oct 2013    Post subject: rear wheel refitting how ? Reply with quote
Seems like a simple task lift up wheel insert spacers and axle do up job done.Fuck no took me nearly 3/4 hour to refit the bloody thing.How the hell are you supposed to lift wheel insert axle and spacers with two hands? .Finaly got it done by balencing wheel on my foot a lifting which caused all mighty cramp .Think i need some bcf tips here Very Happy
cheers john
Quote Me Happy
PostPosted: 20:50 - 08 Oct 2013    Post subject: Reply with quote
Sounds like how I go about it Laughing
Next time I might whip a trolley jack out and use that.
Commuter_Tim
PostPosted: 20:52 - 08 Oct 2013    Post subject: Reply with quote
Get bigger shoes? Razz
I ride a Bandit 600... badly.
Suntan Sid
PostPosted: 20:55 - 08 Oct 2013    Post subject: Reply with quote
Work out, roughly, the height the wheel needs to be above the ground, then make a wedge out of a block of wood!
fatpies
PostPosted: 21:01 - 08 Oct 2013    Post subject: Reply with quote
You simply put the wheel on the toes of your shoes making a best guess, then with one hand keep the wheel stable. With the other hand pushing the spindle in. If it doesn't go in you move your feet inwards closer together lifting the wheel up a bit.
delsol
PostPosted: 21:11 - 08 Oct 2013    Post subject: Re: rear wheel refitting how ? Reply with quote
cheers john
You don't need any tips, that 3/4 hour was well worth it, you're on the learning curve.
Sometimes pain is involved, well done mate, Thumbs Up
sidewinder
PostPosted: 21:18 - 08 Oct 2013    Post subject: Reply with quote
Cheers all.it looks so easy seeing somebody else doing it Very Happy
PostPosted: 21:46 - 08 Oct 2013    Post subject: Reply with quote
It's easier if the rear calliper is not attached.
yen_powell
PostPosted: 22:01 - 08 Oct 2013    Post subject: Reply with quote
I keep two concrete paving blocks in the garage. With these you can position the wheel in exactly the right place and at the right height. Then you can push the axle back in with one hand whilst yawning casually and checking your nails on the remaining hand.
XT1200Z and a DR350 in bits
bridgedino
PostPosted: 22:03 - 08 Oct 2013    Post subject: Reply with quote
Your doing it the same way I do, just keep practicing.
PostPosted: 22:25 - 08 Oct 2013    Post subject: Reply with quote
Go and do it again, you'll be quicker this time.
Islander
PostPosted: 22:28 - 08 Oct 2013    Post subject: Reply with quote
You could always buy one of these...
https://www.abbastands.co.uk/product_details.asp?id=15 Razz
PostPosted: 22:30 - 08 Oct 2013    Post subject: Reply with quote
Hand Using that would be cheating.
Balancing the wheel on your foot whilst putting the axle and spacers in is an essential life skill.
Raffles
PostPosted: 22:50 - 08 Oct 2013    Post subject: Reply with quote
I usually rig-up a ''see-saw'' arrangement using a suitable length of timber and a makeshift fulcrum such as a brick. I place one end of the timber under the rear wheel and I kneel on the other end. The wheel is effortlessly lifted into place and my hands are left free to fit the spindle and spacers etc.
sidewinder
PostPosted: 23:47 - 08 Oct 2013    Post subject: Reply with quote
I realised that about 1/2 hr in Embarassed
Good advice as always guys will pop it off again tomorrow and try and beat my time Thumbs Up
TheSmiler
PostPosted: 01:12 - 09 Oct 2013    Post subject: Reply with quote
Ok this was on the CG but basically put the axle bolt through the left spacer and then lift the wheel up slightly. The bolt will slide into the wheel then just tap the bolt with a rubber mallet and rest on foot whilst you get the other spacer in position. then push bolt all the way through.
Now you have done that take it all apart again as you forgot the chain tensioner Embarassed
defblade
PostPosted: 07:07 - 09 Oct 2013    Post subject: Reply with quote
I sit cross-legged under the swingarm so I'm resting the wheel on the cross of my legs, and it's easy to reach the axle. Apart from that, just like everyone else. The ABS sensor is a right git to get past the disc if everything's lined up; even the tyre place guy had trouble.
jjdugen
PostPosted: 07:42 - 09 Oct 2013    Post subject: Reply with quote
Once again I extoll the virtues of a hoist. If you are servicing your machine on a regular basis, an electric winch fixed to a ceiling support in your garage makes so many jobs so much easier. Picked mine up from Lidl for £25, worth its weight in gold. Use some heavy gauge nylon rope around subframe or headstock to lift and position the bike over front or back wheels. Nice and secure, no toppling over. Makes engine removal a doddle, suspension work too.
Acemastr
PostPosted: 12:15 - 09 Oct 2013    Post subject: Reply with quote
I changed the rear pads a while back and it actually took me longer to get the rear wheel back on than changing the pads, i used a WD40 can sideways and my foot to lever it up, took about an hour of swearing and shouting
2016 Toyota Tacoma Limited
map
Mr Calendar
PostPosted: 12:33 - 09 Oct 2013    Post subject: Re: rear wheel refitting how ? Reply with quote
sidewinder wrote:
...Think i need some bcf tips here Very Happy
Get someone to help you.
Four hands are better than two Wink Very Happy
PostPosted: 13:27 - 09 Oct 2013    Post subject: Reply with quote
Sell your bike. Buy one with a single sided swingarm. Lift the wheel onto the studs, tighten the nuts down.
Otherwise I also sit directly behind the bike, facing the front and lift the wheel into place using a foot. You can also pull the back of the bike down onto the wheel with the wheel on the ground if you have a mainstand.
sidewinder
PostPosted: 17:54 - 09 Oct 2013    Post subject: Reply with quote
Today used a few of the tips Very Happy
1/2 a hour today.Soon be changeing wheels on the tt (not) Very Happy
PostPosted: 18:01 - 09 Oct 2013    Post subject: Reply with quote
I do recall the rear wheel spacers on my KLE500 being a bit of a sod.
I filed a slight chamfer on the outside edge of it where it butts against the chain adjuster which made it easier to move into position at a slight angle rather than having it fall out.
PostPosted: 18:12 - 09 Oct 2013    Post subject: Reply with quote
I also cover the spacers in grease to give some adhesion to the bearing/seal
misscrabstick
PostPosted: 21:57 - 09 Oct 2013    Post subject: Reply with quote
Longish thin plank of wood and a brick, use the plank as a lever and the brick as a height adjuster under the plank to hold it all at the height you want.
The last post was made 12 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 125.29 Kb
