| sidewinder |
 sidewinder World Chat Champion
 Posted: 20:36 - 08 Oct 2013 Post subject: rear wheel refitting how ? |
Seems like a simple task lift up wheel insert spacers and axle do up job done.Fuck no took me nearly 3/4 hour to refit the bloody thing.How the hell are you supposed to lift wheel insert axle and spacers with two hands? .Finaly got it done by balencing wheel on my foot a lifting which caused all mighty cramp .Think i need some bcf tips here
cheers john |
 ..... Quote Me Happy
 Posted: 20:50 - 08 Oct 2013 Post subject: |
Sounds like how I go about it
Next time I might whip a trolley jack out and use that. |
| Commuter_Tim |
 Posted: 20:52 - 08 Oct 2013 Post subject: |
Get bigger shoes?  ____________________ The above post is most likely nonsensical.
I ride a Bandit 600... badly. |
| Suntan Sid |
 Posted: 20:55 - 08 Oct 2013 Post subject: |
Work out, roughly, the height the wheel needs to be above the ground, then make a wedge out of a block of wood! ____________________ "Everybody needs money, that's why they call it money!"  |
| fatpies |
 fatpies World Chat Champion
| delsol |
 delsol World Chat Champion
| sidewinder |
 Posted: 21:18 - 08 Oct 2013 Post subject: |
Cheers all.it looks so easy seeing somebody else doing it  |
| chris-red |
| yen_powell |
| bridgedino |
 bridgedino Spanner Monkey
| Ste |
 Ste Not Work Safe
| Islander |
 Islander World Chat Champion
 Posted: 22:28 - 08 Oct 2013 Post subject: |
| Ste |
 Ste Not Work Safe
 Posted: 22:30 - 08 Oct 2013 Post subject: |
Using that would be cheating.
Balancing the wheel on your foot whilst putting the axle and spacers in is an essential life skill. |
| Raffles |
 Raffles World Chat Champion
| sidewinder |
| TheSmiler |
 TheSmiler World Chat Champion
 Posted: 01:12 - 09 Oct 2013 Post subject: |
Ok this was on the CG but basically put the axle bolt through the left spacer and then lift the wheel up slightly. The bolt will slide into the wheel then just tap the bolt with a rubber mallet and rest on foot whilst you get the other spacer in position. then push bolt all the way through.
Now you have done that take it all apart again as you forgot the chain tensioner  ____________________ CB125>CG125>GN125>ER5>K100RS>R1100RS>K100RS
A2 completed 23/07/15 Ready for the Golden Crisp Packet |
| defblade |
 defblade World Chat Champion
 Posted: 07:07 - 09 Oct 2013 Post subject: |
I sit cross-legged under the swingarm so I'm resting the wheel on the cross of my legs, and it's easy to reach the axle. Apart from that, just like everyone else. The ABS sensor is a right git to get past the disc if everything's lined up; even the tyre place guy had trouble. ____________________ Honda Varadero 125cc => Suzuki Bandit 650 33bhp => 77bhp =>
BMW K1200R Sport 163bhp => Aprilia Shiver GT 750 95bhp |
| jjdugen |
 jjdugen World Chat Champion
| Acemastr |
 Acemastr World Chat Champion
| map |
 map Mr Calendar
 Posted: 12:33 - 09 Oct 2013 Post subject: Re: rear wheel refitting how ? |
 Posted: 13:27 - 09 Oct 2013 Post subject: |
Sell your bike. Buy one with a single sided swingarm. Lift the wheel onto the studs, tighten the nuts down.
Otherwise I also sit directly behind the bike, facing the front and lift the wheel into place using a foot. You can also pull the back of the bike down onto the wheel with the wheel on the ground if you have a mainstand. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| sidewinder |
 Posted: 17:54 - 09 Oct 2013 Post subject: |
Today used a few of the tips
1/2 a hour today.Soon be changeing wheels on the tt (not)  |
 Posted: 18:01 - 09 Oct 2013 Post subject: |
I do recall the rear wheel spacers on my KLE500 being a bit of a sod.
I filed a slight chamfer on the outside edge of it where it butts against the chain adjuster which made it easier to move into position at a slight angle rather than having it fall out. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| chris-red |
| misscrabstick |
 misscrabstick Crazy Courier
The last post was made 12 years, 359 days ago. Instead of replying here, would creating a new thread be more useful? |
