| podmore71 |
 podmore71 Borekit Bruiser
 Posted: 14:56 - 28 Apr 2014 Post subject: New Tool and now a little nervous |
I've purchased a Neilsen 1/2" Air Impact Wrench from ebay and I'm afraid to say, it scares the hell out of me before I even use it.
For starters, the instruction manual is not the best i have seen and I am a little confused as to how I go about using it. It comes with an attachment which I believe is the 'oil pot' but I am unsure where this should go or what it is for exactly. Also, the various size sockets don't exactly stay on very snuggly. Certainly nothing like they do on a conventional socket set. Is this normal?
Also, on the side of the gun, there is a location marked 'Oil'. Do i need to put some in before I use it?
Any advice would be much appreciated. I need this to remove my front wheel, so that I can try and sort out my front suspension on my little Honda.
https://i.imgur.com/AOdJVxAl.jpg
https://i.imgur.com/9xtyVSil.jpg |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 15:00 - 28 Apr 2014 Post subject: |
Why not remove your front wheel with a conventional breaker bar?
I've never used air tools, so can't help, but they're not needed to do any jobs on a motorcycle. Using a breaker bar is a piece of cake. ____________________ My Flickr |
| covent.gardens |
 covent.gardens World Clap Champion
| Vincent |
 Vincent Banned
| janner_10 |
 janner_10 World Chat Champion
| stinkwheel |
 Posted: 16:19 - 28 Apr 2014 Post subject: |
I would and have used them on a bike but for specific jobs.
Such as uber tight nuts like the stub axle nut on a single sided swingarm and some crank end bolts. Nuts on rotating parts like a clutch centre nut or the bottom bolt on a fork leg.
And on both uber-tight and rotating nuts like front sprocket nuts.
With regard to the impact wrench, yes, impact wrenches don't have a little ball catch to hold the socket on so it simply slides on and off the end.
If it's only for occasional use, I usually just put a few drops of oil down the end of the air inlet before each use.
There is a knob on the bottom that sets the "hit rate" 1 being lowest, 4 being highest. I usually start at 1.
There should be a label on it stating the required working pressure.
So lock the pressure regulator on your compressor to that working pressure, put a few drops of oil down the air inlet of the wrench. Attach the airline (either by screwing it on or by using the quick-release fitting). Select your socket, ensure it is firmly set on the fitting, check the wrench is set to spin the correct way (there is a forward and reverse switch), attach the wrench and pull the trigger.
Should clatter some then undo the fitting. If it doesn't, increase the hit rate and try again. Use your common sense, if it simply isn't moving, check for reasons why and keep an eye on the state of the head of the fitting.
If you're using it for suspension, I presume you're meaning to undo the bottom bolts without the cartridge spinning. You'll need a fairly long, 1/2" drive allen key for that. These aren't impact grade, be warned there is a risk they will shatter when used in an impact wrench so wear eye protection. In reality it doesn't happen, I've done the job many times but you only have one set of eyes. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MarJay |
 MarJay But it's British!
| The Artist |
 The Artist Super Spammer
| gavcarter |
 gavcarter Could Be A Chat Bot
 Posted: 18:50 - 28 Apr 2014 Post subject: |
I use a cheapie one quite often, couple of drops oil in the grub screw before use.
Mine is the opposite to yours the sockets are a bugger to get back off, but mine is fitted with a retainer ring that I assume proper impact sockets have a recess for - but i just use normal sockets on mine.
As long as they are decent brand and 6 sided ive never hit any problems.
Snapped a couple of engine mounting bolts when i "tested" the gun though- was a case of "o0o0o look new toy what can i overtighten"  |
| CHR15 |
 CHR15 Turbo nutter bastard
 Posted: 19:21 - 28 Apr 2014 Post subject: |
never use it to tighten things up. ____________________ Turbocharged drag thing / project death weapon / GK73A
Ste: I'm not entirely sure how you'd go about verbally abusing someone with a potato but I'm sure it's possible. |
| podmore71 |
| recman |
 recman World Chat Champion
 Posted: 09:21 - 29 Apr 2014 Post subject: |
Used to use one of those at work but only for speed.
They have their place, I wouldn't bother with it on my bike but then I have arms with a little more girth than a pipe cleaner.  |
 ........................ Spanner Monkey
| MarJay |
| stinkwheel |
 Posted: 13:44 - 29 Apr 2014 Post subject: |
I'd like to know how all these people are getting fork bottom bolts and clutch centre nuts off with their breaker-bars. Or do you keep/fabricate a clutch lockup and holding tool for each bike?
I also use mine to put clutch centre nuts back on again. If theyare not piked anyway, I mark the position it was in with a scribe and rattle it back to the same place.
Also very useful for the gearbox mainshaft on the Enfield which has a nut on either end threaded in opposite directions (so tightening one, undoes the other if you hold both of them). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| slowlydoesit |
 slowlydoesit Could Be A Chat Bot
| stinkwheel |
| Shaft |
 Shaft World Chat Champion
| Coxyzxr |
 Coxyzxr Brolly Dolly
| merquis00 |
 merquis00 Nova Slayer
| Vincent |
 Vincent Banned
| stinkwheel |
| Shaft |
| stinkwheel |
The last post was made 12 years, 203 days ago. Instead of replying here, would creating a new thread be more useful? |
