New Tool and now a little nervous
podmore71
PostPosted: 14:56 - 28 Apr 2014    Post subject: New Tool and now a little nervous Reply with quote
I've purchased a Neilsen 1/2" Air Impact Wrench from ebay and I'm afraid to say, it scares the hell out of me before I even use it.
For starters, the instruction manual is not the best i have seen and I am a little confused as to how I go about using it. It comes with an attachment which I believe is the 'oil pot' but I am unsure where this should go or what it is for exactly. Also, the various size sockets don't exactly stay on very snuggly. Certainly nothing like they do on a conventional socket set. Is this normal?
Also, on the side of the gun, there is a location marked 'Oil'. Do i need to put some in before I use it?
Any advice would be much appreciated. I need this to remove my front wheel, so that I can try and sort out my front suspension on my little Honda.
https://i.imgur.com/AOdJVxAl.jpg
https://i.imgur.com/9xtyVSil.jpg
PostPosted: 15:00 - 28 Apr 2014    Post subject: Reply with quote
Why not remove your front wheel with a conventional breaker bar?
I've never used air tools, so can't help, but they're not needed to do any jobs on a motorcycle. Using a breaker bar is a piece of cake.
covent.gardens
World Clap Champion
PostPosted: 15:10 - 28 Apr 2014    Post subject: Reply with quote
My air ratchet only lasted 5 minutes and never worked properly... never found out whether it was because I didn't use an inline oil thingy, or it was cheap crap, or the compressor wasn't up to it.
Someone needs to write an idiot's guide to air tools.
janner_10
PostPosted: 15:12 - 28 Apr 2014    Post subject: Reply with quote
I wouldn't use one a bike, a decent socket set if by far more useful than.
If its a cheapo Ebay job and especially if the sockets aren't a good fit then check that it is actually metric - if its imperial you may as well throw it away.
In fact, if the sockets don't fit heads well you may as well throw it away.
We lubricate ours at work with a couple of drops of 3 in one every week or so - that's all it needs.
EDIT: Thats drops into the air inlet I should add.
PostPosted: 16:19 - 28 Apr 2014    Post subject: Reply with quote
I would and have used them on a bike but for specific jobs.
Such as uber tight nuts like the stub axle nut on a single sided swingarm and some crank end bolts. Nuts on rotating parts like a clutch centre nut or the bottom bolt on a fork leg.
And on both uber-tight and rotating nuts like front sprocket nuts.
With regard to the impact wrench, yes, impact wrenches don't have a little ball catch to hold the socket on so it simply slides on and off the end.
If it's only for occasional use, I usually just put a few drops of oil down the end of the air inlet before each use.
There is a knob on the bottom that sets the "hit rate" 1 being lowest, 4 being highest. I usually start at 1.
There should be a label on it stating the required working pressure.
So lock the pressure regulator on your compressor to that working pressure, put a few drops of oil down the air inlet of the wrench. Attach the airline (either by screwing it on or by using the quick-release fitting). Select your socket, ensure it is firmly set on the fitting, check the wrench is set to spin the correct way (there is a forward and reverse switch), attach the wrench and pull the trigger.
Should clatter some then undo the fitting. If it doesn't, increase the hit rate and try again. Use your common sense, if it simply isn't moving, check for reasons why and keep an eye on the state of the head of the fitting.
If you're using it for suspension, I presume you're meaning to undo the bottom bolts without the cartridge spinning. You'll need a fairly long, 1/2" drive allen key for that. These aren't impact grade, be warned there is a risk they will shatter when used in an impact wrench so wear eye protection. In reality it doesn't happen, I've done the job many times but you only have one set of eyes.
PostPosted: 17:06 - 28 Apr 2014    Post subject: Reply with quote
The inline oiler goes on the air line between the end of the hose and the connection on the handle of the air wrench. The oil hole has a plug in it on mine which I open and add some 3 in 1 every so often. I don't use an inline oiler as I don't have enough connectors to add it to the system but I just use 3 in 1 as I said.
The Artist
PostPosted: 17:09 - 28 Apr 2014    Post subject: Reply with quote
ITT: Everyone hating on air tools.
Get some air tool oil is step 1.
Does it have a brand name?
gavcarter
PostPosted: 18:50 - 28 Apr 2014    Post subject: Reply with quote
I use a cheapie one quite often, couple of drops oil in the grub screw before use.
Mine is the opposite to yours the sockets are a bugger to get back off, but mine is fitted with a retainer ring that I assume proper impact sockets have a recess for - but i just use normal sockets on mine.
As long as they are decent brand and 6 sided ive never hit any problems.
Snapped a couple of engine mounting bolts when i "tested" the gun though- was a case of "o0o0o look new toy what can i overtighten" Embarassed Embarassed Embarassed
CHR15
Turbo nutter bastard
PostPosted: 19:21 - 28 Apr 2014    Post subject: Reply with quote
never use it to tighten things up.
podmore71
PostPosted: 08:36 - 29 Apr 2014    Post subject: Reply with quote
Thanks for will the advice guys. Made me feel much better.
I won't be using it that often. I only bought it so I could get the wheels off and at some point, the variator nut.
recman
PostPosted: 09:21 - 29 Apr 2014    Post subject: Reply with quote
Used to use one of those at work but only for speed.
They have their place, I wouldn't bother with it on my bike but then I have arms with a little more girth than a pipe cleaner. Wink
PostPosted: 09:24 - 29 Apr 2014    Post subject: Reply with quote
I've got one, it comes out very rarely but it's good to have one for when you need it. A front sprocket nut being a prime example.
PostPosted: 13:16 - 29 Apr 2014    Post subject: Reply with quote
They are useful, flywheel nut being another example. I gave the flywheel nut on my pitbike a brief brief blast with the windy gun on the lowest setting just to nip it up as otherwise the flywheel turns when you get a socket on it. I'd have never been able to undo it without the windy gun anyway.
PostPosted: 13:44 - 29 Apr 2014    Post subject: Reply with quote
I'd like to know how all these people are getting fork bottom bolts and clutch centre nuts off with their breaker-bars. Or do you keep/fabricate a clutch lockup and holding tool for each bike?
I also use mine to put clutch centre nuts back on again. If theyare not piked anyway, I mark the position it was in with a scribe and rattle it back to the same place.
Also very useful for the gearbox mainshaft on the Enfield which has a nut on either end threaded in opposite directions (so tightening one, undoes the other if you hold both of them).
slowlydoesit
PostPosted: 13:57 - 29 Apr 2014    Post subject: Reply with quote
Is it useful/desirable to have an impact driver with controllable torque or are they essentially all or nothing tools? I suspect it doesn't matter when loosening fasteners but when tightening it looks like this kind of wrench could easily overdo it?
Kawasaki KMX200 with broken fixed powervalves and a stutter
PostPosted: 14:40 - 29 Apr 2014    Post subject: Reply with quote
Not really all or nothing as such but the longer you squeeze the trigger for, the tighter it will make it. Yes, you could easily overdo it so take care.
I work on the principal that if the fitting has been turned back onto the thread it came off by the same number of turns it was previously, it will be stretched by the same amount. So I put it back in the same position. A lot of cylinder head nuts are done by degrees of turning rather than torque these days.
Shaft
PostPosted: 18:33 - 29 Apr 2014    Post subject: Re: New Tool and now a little nervous Reply with quote
If you're having to use an impact gun to remove your front spindle nut, it's either been massively overtorqued or there's a corrosion issue.
Use the gun to crack it off, but put it back on with a torque wrench and clean and lightly coat the spindle thread with copper paste.
As others have said, there are very few bike fixings that need the brute force of impact wrenches, but loads of them can be totally destroyed.
A decent torque wrench is a much more useful tool.
Coxyzxr
PostPosted: 18:42 - 29 Apr 2014    Post subject: Reply with quote
Me too!
**WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID !
merquis00
PostPosted: 21:12 - 29 Apr 2014    Post subject: Reply with quote
Coxyzxr wrote:
Me too!
https://www.mattwebb.com.au/cbr/socket.jpg
Current: 2010 WR125X, Carrera crossfire-E.
Project's: '88 GL1500 Trike, Chinese 170cc Monkey
Previous: X9-500, XT125, DNA125, CBF125, YZF-R125, '98 K1200RS, '99 St1100, fantic245
PostPosted: 23:27 - 29 Apr 2014    Post subject: Reply with quote
I bought Honda tool part number: 07716-0020100
https://www.davidsilverspares.co.uk/graphics/parts/077160020100.jpg
Having the correct tool rocks.
Jamming the primary gears will only stop the outer basket rotating, not the centre.
Shaft
PostPosted: 00:03 - 30 Apr 2014    Post subject: Reply with quote
Indeed it does and, in my extensive experience, an impact gun is not often the right tool.
PostPosted: 08:09 - 30 Apr 2014    Post subject: Reply with quote
The Honda special tool for removing castellated clutch centre nuts is an impact grade socket.
The last post was made 12 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 130.76 Kb
