BMW... The cars...
dextersaurus
PostPosted: 21:01 - 01 May 2014    Post subject: BMW... The cars... Reply with quote
Looking at E46 320ds...
What would you consider high mileage for one of these, considering they're about 10 years old.
Found one with 86k miles on it, which seemed in decent enough nick, but then there's so many with 100-150k miles on them... What would you lot consider as high mileage? what would you touch, what would you stay away from?
Having owned one diesel, and i blew it up, i'm not too sure.
Cheers,
PostPosted: 21:13 - 01 May 2014    Post subject: Reply with quote
Diesels are a lot less smooth than petrols, and they tend to wear their engine mounts and become even more rattly as time goes on.
Really you need to drive it and see, but in my experience like most Japanese cars over 100k is the tested limit of these cars, and after that you start to get unexpected failures of things like electric window motors etc.
Personally I'd stick with the approximately 80k bracket, although I probably wouldn't touch a 320d tbh.
I had a 135k E36 325i and it was a good car, but it was let down by component failures due to age and mileage.
PostPosted: 21:15 - 01 May 2014    Post subject: Reply with quote
BMW Diseasel!?! WTF is wrong with you?
Razz
CHR15
Turbo nutter bastard
PostPosted: 21:54 - 01 May 2014    Post subject: Reply with quote
i had one for 4 months.
it had;
new clutch
new flywheel
all subframe / diff mounts
gearbox mounts
engine mounts
pads and discs all round
2 x abs sensors
drop links
front arb bushes
rear springs
egr thermostat
main thermostat
maf sensor
i got a little bit fed up of replacing something every week so i flipped it on for a grand with 152k on it.
after having a straight 6 petrol beemer now i really miss the low down grunt of a diesel although the 4 pot motors are proper rough and loud compared to the 6 pot ones.
clancy
PostPosted: 22:01 - 01 May 2014    Post subject: Reply with quote
Get an a4 if you want that size car and diesel, my mates is on 220 k miles, still on the original engine and gearbox. Had nothing except consumables go on it basically
I would not be put off by huge miles on a bmw or similar car, it depends how it did thise miles, loads are use nearly just for motorway miles
I'd rather have 130 k miles that's just been sitting on the motorway than 70k that's been ragged to shit round town all its life
KLX 300r
Benson_JV
PostPosted: 22:03 - 01 May 2014    Post subject: Reply with quote
This. A4 1.9TDI - will keep on going, going, going and going. If respected.
dextersaurus
PostPosted: 22:04 - 01 May 2014    Post subject: Reply with quote
i've got a 152k mile 6 gen celica just now, and it's falling to bits, so need something a bit... more reliable?
320d was the first choice. then a mk4 golf GT TDI...
Vracktal
PostPosted: 22:31 - 01 May 2014    Post subject: Reply with quote
My dad has the E46 320i (I6 Petrol) touring.
Bought it last week, it had 16,000 miles on it (not a typo, last owner was a little old lady who bought it new then drove it hardly ever) and so far it's needed 1x ABS sensor (r/o wheel) Replaced under dealer warranty but hoping it's not a sign of things to come...
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
arry
PostPosted: 00:40 - 02 May 2014    Post subject: Reply with quote
Get a 330d and buy on condition not mileage.
I've had a fantastic experience with mine over 3 years and a lot of miles. It has cost me so little and is such a great drive. I did 550 miles in one sitting and didn't even stop for fuel - I'd do the same again. Brilliant car
Shaft
PostPosted: 07:23 - 02 May 2014    Post subject: Reply with quote
Two major issues with a 320d:
Blocked crankcase breathers, leading to excessive smoke and crankcase pressure and inlet swirl flap failure.
Both are relatively cheap to fix, but you want to make sure they have been, especially the swirl flaps, because they ingest them and blow the engine.
There is no warning sign, they just go, so have them removed and blanked off.
A good oil change history is also very important, as they like a turbo if the oil isn't kept fresh.
daemonoid
PostPosted: 07:32 - 02 May 2014    Post subject: Re: BMW... The cars... Reply with quote
Cheers,
My 330d has 330,000 km on it and still feels strong.
current: ducati monster 750
arry
PostPosted: 07:48 - 02 May 2014    Post subject: Reply with quote
186,000 miles on mine. Interior is like new. Only issue I've had with it is a lift pump - £150 to put right - that's in 3 years and 48,000 miles.
daemonoid
PostPosted: 10:48 - 02 May 2014    Post subject: Reply with quote
mpd72 wrote:
This goes back to the old story of Parkers or someone similar, who ran a long term test of a 530i petrol and a 530D. The diesel stormed ahead on running costs until the mileage crept up and the diesel started needing some pretty expensive engine components. In the end the petrol worked out slightly cheaper to run, due to not needing major engine components at high mileage.
Oooh, interesting... Can you find the source? Dealer prices I guess? Wonder what the difference would be if you did the work yourself?
I, like most people I guess, assumed that diesel was always the way to go for high mileage.
I should add that while my bm has done 330,000km I still hate it. The throttle response is atrocious, yet it goes through rear tyres like I don't know what, it has a strange combination of ultra stiff suspension and body roll. It just feels horrible to drive... I'd get rid of it if it weren't so reliable and would never've bought it if it weren't for the ultra low price I got it for.
arry
PostPosted: 12:40 - 02 May 2014    Post subject: Reply with quote
Do a throttle adaptation reset:
1 Place key in ignition and turn to detent 1 and count for 10 seconds ( only postion 1 do not start the engine. )
2.Turn key back to 0 postion and count for another 10 seconds
3.Now turn the key all the way to detent 3 to start the engine
Must be something wrong - I've consistently got 20,000+ miles out of my rears
M Sport? Laughing Notoriously poor ride quality. Mine's the SE - I was mocked for buying an SE originally but I don't care, it's the better car.
Mine feels excellent. Possible worn / soggy suspension components including the front track control arm / balljoints? Snapped rear springs?
arry
PostPosted: 12:45 - 02 May 2014    Post subject: Reply with quote
mpd72 wrote:
The 530i is approx 7mpg less economical than the 530d in any given situation - if the 530d is doing 45mpg on the Motorway the 530i is doing 37mpg, if the 530i is getting 21mpg around town the 530d was getting no better than 28mpg.
Now that I would find very interesting. From my perspective, in all the research I did, near 40mpg on a run is unheard of from the 30i.
Further interesting that I'd suggest 37mpg would be driving as economically as possible and then being optimistic. I can crack 50mpg in mine (automatic, too) if I'm delicate - I just never am, because I'm leadfooted, and therefore I average 38mpg.
daemonoid
PostPosted: 13:27 - 02 May 2014    Post subject: Reply with quote
No-one's even sure whether that's placebo or not... Anyway, it's not the problem, the problem is I'm used to the throttle response on higher performing vehicles rather than a big turbo diesel. It's great once I've spun the turbo up, or when I'm starting from stationary.
I do corner quicker than most and was 'drifting' it last night to annoy the missus... maybe that's the problem. I'm also used to lighter cars that obviously don't put the same abuse through the rubber.
Nah, touring with a factory fit towbar... the problem is the suspension is set up for heavy loads or towing and without being full it just doesn't sit right. Everyone else I've spoken to with the same car&options says the same (sample size of 3 including me).
Front ball joints do need replacing (keep meaning to get around to it), but it's not the real issue. The problem is it's 1.5t of barge that's meant to be wafted, not driven. It's designed for autobahns, not fun. The fact that 6th doesn't even bother pulling until you're above 130kph is evidence of that.
Maybe my criteria are different to most people - I like fun cars, which normally means small. I like instant throttle response (as in nose of the car rises on every blip).
MarkJ
PostPosted: 13:58 - 02 May 2014    Post subject: Reply with quote
Could it also be run flat tyres?
st3v3
PostPosted: 14:51 - 02 May 2014    Post subject: Reply with quote
Too many people get caught up in how many miles a motor has, how many miles it's got can have nothing to do with its condition.
Proven receipts, work done and how it sounds/feels to drive are what matter.
Can very easily have a car with 15K on the clock that's been ragged to the brink of death and sold for full market value, doesn't mean it's worth the cash. Karma
daemonoid
PostPosted: 15:31 - 02 May 2014    Post subject: Reply with quote
No
dextersaurus
PostPosted: 16:37 - 02 May 2014    Post subject: Reply with quote
I've always been under the impression 100k isn't really high mileage. 150k would be the highest i would go. The car's only really for back and forward to work, about 250 miles a week, and longer runs around the country. current car i'm doing about 1500 a month during the summer.
so some of you say they're good cars, others say they're shit. I've got a limit of about £1500, so an audi (unless it's an old pre-facelift model) is really out of the question. 320d seems within my budget and can find ones that look in great condition. if i could afford a 330d i'd get one. i won't be going for the estate, it'll be the saloon. as long as it has enough space to ride a dirty in the front i'm happy.
Like i said, i'd love the BMW, but my second choice would be a mk4 golf GT TDI.
So basically, just do all the checks i normally would, and as long as it's below 150k it should be alright. i'm not fussed about spending money on it, i do it myself and the parts can be had cheap enough, so if bits and pieces start to fail at that kind of mileage i'm not too fussed. I've spent enough money and time on cars i should have a fucking ferarri by now.
Thanks for all the advice though.
PostPosted: 16:44 - 02 May 2014    Post subject: Reply with quote
100k is definitely where Japanese cars start to fail. My suspicion is that German manufacturers test up until 200,000km which is approximately 125000 miles. This is bourne out by the fact that my E36 was pretty tired by 130k miles.
Clutchy
PostPosted: 17:12 - 02 May 2014    Post subject: Reply with quote
I agree that the amount of mileage on a car may not reflect the condition of the engine and engine components but it definitely reflects the condition of the interior and the amount of time the car has potentially spent in the winter.
For example a 150k car has probably used the electric windows etc a lot more than a 100k car.
That car has also had an extra 50k worth of use on the suspension, window wiper motors etc etc which when little things like that start to fail, it adds up for sure.
Back to OP I very much like the GT TDI golfs but at that age can come with a myriad of minor problems, the most annoying being the door lock modules.
The last post was made 12 years, 196 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 147.12 Kb
