Should I be getting rid of my small diesel estate?
Wonko The Sane
PostPosted: 15:41 - 04 Aug 2014    Post subject: Should I be getting rid of my small diesel estate? Reply with quote
Spotted this and a few other news 'stories' this mornin'
https://www.telegraph.co.uk/earth/environment/11006048/Diesel-drivers-should-be-fuming.html
up-shot is, small eco diesels that have been encouraged by lower tax due to low CO2 emissions are partly responsible for the smog we keep getting and the fines the EU hands out for breaching polution levels.
A couple of years ago we bought a 1 year old Ibiza Estate 1.2 diesel for two reasons 1) lots of long drives to visit family back up north, 2) cheaper all in running costs of tax + fuel
We've since moved up north ourselves (north of Manchester) so the we're not doing long journeys as often and the congestion charging issue is of no worry but we find the car a bit underpowered on the steep hilly bits around here (there's one hill start around here that I have to either rev the nuts of and hope I don't wheel spin or I'll stall.) and thinking that if VED for diesel cars is set to rise we might be best moving it on and getting something else.
Any oppinions on it?
I can live with the slight underpowered nature of the car but don't want to be stuck with a car falling in value while costs of running it rise.
daemonoid
PostPosted: 15:56 - 04 Aug 2014    Post subject: Reply with quote
All previous major VED overhauls have not modified the situation for existing vehicles, so that *shouldn't* be a problem.
Congestion charging will take years before it makes it out to Manchester, especially considering the defeat of it last time it was tried.
You shouldn't be stalling a diesel on hills - they're all torque so you're doing something wrong! And before you ask... Yes I do have some experience of the roads given I have some family in the wilds of Derbyshire.
current: ducati monster 750
stevo as b4
PostPosted: 16:28 - 04 Aug 2014    Post subject: Reply with quote
I wouldn't say diesels are all torque, but typically nasp one's develop peak torque at about 1/2 max power engine speed, and turbo diesels often peak lower, though sometimes the torque never actually is allowed to peak, and is modulated to protect the gearbox/clutch.
Older diesels always had a governor that would try to stop a stall, by adding fuel if the load increased on the engine.
But if the engine load is too high for it and applied to suddenly then a diesel will still stall, if it hasn't got the torque to overcome the load applied.
I've always had more time for older diesels as they are simpler to work on and there's only very few seriously expensive parts that can fail, but as long as they are maintained well and not run on used chip fat all the time, they seem to be fairly tough!
Anything Common rail with ECU engine control is more of a pain, and things can go wrong more often, but later 2004> engines with DPF's are even worse and for short small journeys with lots of stop and start, and gentle driving are not worth the hassle.
Start doing big mileages then diesel is at least worth considering, but by no means conclusively better.
Llama-Farmer
PostPosted: 16:44 - 04 Aug 2014    Post subject: Reply with quote
The problem I bet comes mostly from older taxis and minicabs... 90% of the vehicles I see throwing out clouds of black smoke are a taxi of some kind, and most black cabs are 10-15 years old around here, most minicabs 5-10 years old.
Yet I bet most of the diesel cars in centre of towns that would be subject to a congestion charge are much less polluting than the majority of ones that would be exempt as taxis.
Cars fall in value anyway, costs of running them increase as parts get old and fail outside of warranty. Eventually it comes a time where replacing it with a newer car is cheaper than fixing everything that breaks.
I'd just keep it until its no longer viable, don't get rid in anticipation of something that might not happen
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
PostPosted: 17:10 - 04 Aug 2014    Post subject: Reply with quote
Regardless of what may or may not change with VED, of course you should get rid of your 1.2 diseasel.
Set fire to it rather than selling it to some other poor mug then use the profits to buy yourself something that's fun to drive. Dinodiesel stopped being a cheap fuel about ten years ago so get yourself a petrol car and put some fun back into driving.
andys675
PostPosted: 18:50 - 04 Aug 2014    Post subject: Reply with quote
you need to do more than 33000 miles over a 3 year period to make a diesel more cost efficient than a petrol (read in auto express)
krarkol
PostPosted: 18:51 - 04 Aug 2014    Post subject: Reply with quote
stevo as b4 wrote:
I
I think they still do. I learnt in the new shape fiesta which was the diesel version.
In 2nd, you could keep your feet off the pedals and it would pretty much maintain 12mph or so. It would lug and then would kick a bit and drive itself Laughing
Bandit 600 - deaded
PostPosted: 19:33 - 04 Aug 2014    Post subject: Reply with quote
Depends on the particular car.
Parkers price guide have a comparison of petrol and diesel versions of cars on their site. Think for a Fiat 500 the point where a diesel made financial sense was around 300,000 miles.
Vracktal
PostPosted: 19:54 - 04 Aug 2014    Post subject: Reply with quote
The only application i'd consider a diesel engine for is in an offroader, because they deal better in deep water and muck and have the torque to pull out of sticky spots.
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
mentalboy
PostPosted: 20:05 - 04 Aug 2014    Post subject: Reply with quote
Which also makes them useful for towing trailers (and caravans, if that's your thing)
Make mine a Corona.
PostPosted: 20:13 - 04 Aug 2014    Post subject: Reply with quote
It is a spread or toque you want for that. And too many modern diesels rely on a big turbo, and land up with a power band the width of a chocolate mouses cock
bikertomm
PostPosted: 20:14 - 04 Aug 2014    Post subject: Reply with quote
I read somewhere that although diesel may look dirty kicking out all that black soot, and it sure doesn't smell nice - apparently you would last a lot longer in a room full of diesel fumes than you would petrol fumes.
Don't know if this is true or not. Thumbs Up
Wonko The Sane
At the time we were doing over 10,000 a year easily, now perhaps not so much.
The wife's job involves driving from one site to the next so quite a number of short journeys in a day adding to the millage.
good point on the affecting older desiesels or being a revision of rules for cars built / registered after a set date so might as well keep it for a few more years / until we need a bigger car or whatever.
ta
PostPosted: 20:21 - 04 Aug 2014    Post subject: Reply with quote
Depends on the fumes.
The only real nasty that will kill you quickly in exhausts is carbon monoxide. There is very little of this in any modern car exhausts (main thing that cats remove). To the extent it is meant to be virtually impossible to kill yourself with a modern car exhaust.
You can harm yourself with carbon dioxide. But mainly by landing up replacing all the oxygen in the air with carbon dioxide.
Most of the rest are not an issue, but the particle emissions (that diesels are particularly bad for) are not good for you.
On that basis sitting in a room with a running diesel is probably a lot worse than a running petrol.
Llama-Farmer
PostPosted: 01:36 - 05 Aug 2014    Post subject: Reply with quote
Someone on my road where I used to live tried to commit suicide this way... by sitting in their 2011 car in the garage with the engine running.
I was ironically amused that they fell asleep in the car, only to wake up the next day and realise all they'd done was waste about 1/5 of a tank of petrol and steam up all the walls and windows of the garage.
0l0dom0l0
PostPosted: 14:56 - 05 Aug 2014    Post subject: Reply with quote
Part of the problem is technology is too advanced.
Look at what comes out the back of an old school turbo diesel. Big clouds of black smoke. Whilst on the surface it looks bad, the big particles of unburned fuel, or soot are relatively easy for your body to remove.
Modern diesels are creating particles so small that you can't filter them out and such they get in your lungs etc. This is what's causing the problem..
sickpup
Old Timer
PostPosted: 18:29 - 05 Aug 2014    Post subject: Reply with quote
©Barry Sheene iirc?
PostPosted: 20:22 - 05 Aug 2014    Post subject: Reply with quote
Not that easy, and they are small enough to get well into your lungs.
Possible that petrol vehicles are as well.
sickpup wrote:
©Barry Sheene iirc?
Think so, (although not sure I quoted it 100% correctly).
Clutchy
krarkol wrote:
stevo as b4 wrote:
I
Huh??? Thought all cars did this? Unless going up hill I'm yet to use a petrol that didn't do this Shocked
Unless I'm misunderstood
Llama-Farmer
PostPosted: 22:53 - 05 Aug 2014    Post subject: Reply with quote
Modern diesels (2000-onwards) have EGR valves and whatnot to reduce the amount of unburnt fuel in the exhaust.
Very modern diesels (8 or so years) have DPFs which filter out the larger soot particles, that is why newer diesels very rarely smoke, whereas 10-15 year old diesels still chuck out some smoke under acceleration.
The bigger particles are still a problem though, particularly to people with respiratory problems.
stevo as b4
PostPosted: 01:26 - 06 Aug 2014    Post subject: Reply with quote
You need a contact light haze of grey/black smoke coming out of your diesel tailpipe though if you want it to go properly!
Too much fuel before the turbo has spooled, is bad for smoke, but then a little extra fuel and a big free flow exhaust helps turbo's wind up faster. Once on full boost a wisp of black smoke is definitely needed if you want to make horsepower! Thumbs Up
Llama-Farmer
PostPosted: 02:14 - 06 Aug 2014    Post subject: Reply with quote
In the old days maybe.
The only time you get smoke out the back of the 330d I borrowed for a while or the 335d my friends got is when the DPF is regenerating and burning all the soot off.
Under normal ops the exhaust is smokeless. 240 and 280bhp is quite a lot to be making for a standard diesel.
Easily 300/350+ with remaps alone, but people doing that tend to also do things like delete the DPF and remove cats, blank off EGRs, (blank off swirl flaps in the BMWs). All of that means smokey...
0l0dom0l0
PostPosted: 10:37 - 06 Aug 2014    Post subject: Reply with quote
Be careful. EGR isn't to reduce the amount of unburned fuel in the exhaust, it's to lower the combustion temperature and reduce the rate of NOX formation which is the biggest problem for diesels.
In a sense EGR is what causes unburned fuel in the exhaust. EGR spots in the mix hinder the flame front when it travels through the unburned mixture and leave unburned bits behind. EGR particles also reduce the amount of abundant oxygen in the chamber which doesn't help and a lower combustion temperature isn't good for particulates either.
If you read the article they're mainly focusing on NOx, I made the comment about particulates as that's a by product of trying to reduce NOx...... for the reasons above.
I don't expect it will be long before diesels employ SCR. It's pretty common on lorrys from my understanding, but this will make them even more expensive and less desirable.
PostPosted: 11:53 - 06 Aug 2014    Post subject: Reply with quote
There's a couple of articles kicking around by German universities pointing out that cars - particularly turbodiesels - are tuned to scam the emissions test. The ECU detects that it's being run under test conditions, dials back the boost and leans out the fuelling.
Hit the real world and it's a very different story. Emissions, they claim, haven't actually gotten better in the last decade.
What strikes me about the environmentalist (and taxation) obsession with CO2 is that while diesel engines do burn less fuel and so shove less out of the tailpipe, DERV and petrol are both fractioned out of the same crude oil. Unless we're actually, literally, planning on pouring half of it back into the ground, it's all going to get burned by someone, somewhere.
Llama-Farmer
PostPosted: 14:01 - 06 Aug 2014    Post subject: Reply with quote
Yeah true and thats why DPFs are now fitted.
I notice how automotive technology doesn't seem to be happening on diesels... very few prototypes of diesel plug-in hybrids.
I'm surprised there hasn't been more diesel-electric drivetrains tbh, with a diesel generator providing continuous electric power to an electric motor. If it works for trains...
The last post was made 12 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 146.2 Kb
