Speedometer requirements and headlight requirements
ian505050
PostPosted: 21:31 - 04 Jan 2015    Post subject: Speedometer requirements and headlight requirements Reply with quote
I have a Honda CBF250 2007 that i have imported from Spain and i have gone through all the stages required to register it in the UK.
My final requirement now is to put the bike through Partial Vehicle inspection and a DVSA center costing £12.00.
The Partial test will only check the bikes speedometer shows MPH and the headlight aim is correct.
Currently the Speedometer is in KPH only as pictured below and the headlight is set up for use in Spain so it points at on coming traffic .
Below is a link to the requirements for the speedometer (section 4) and headlight (section 6)
https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/366046/msva-manual.pdf
1.) So......... I am thinking as personally i don't mind the clocks showing KPH would i be able to pass the test by fitting a cycle computer with permanently lit up display capable of showing speeds up to 99MPH? The Max speed of the bike in the manual is 80MPH?
https://i267.photobucket.com/albums/ii302/ian505050/ian505050004/20140913_153905_zps089efd91.jpg
2.) Can i fit some form of stick on headlight deflector? Like the ones you get on cars? I can find any specific bike light deflector?
https://i267.photobucket.com/albums/ii302/ian505050/ian505050004/20140913_153841_zpse8108be1.jpg
The sensible option and most expensive option would be to buy a UK spec headlight costing £50 ish plus fitting and find a crash damaged CBF250 and steal the MPH insert out of the clocks and replace my KPH insert that sits behind the speedo gauge. But that's a ball ache.
oh........... a snap of the bike in question
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%203/20141002_192543_zps888ba059.jpg
Its taken 20 different pieces of paperwork to try and get the DVLA to issue me with a V5 and 4 separate attempts applying for the V5 and each time i have had a response they have sent me a couple of different reasons why my application has been rejected.
I sent the first batch of paperwork off knowing it would not be sufficient and they gave me a list of bullet points stating what they needed from me. I responded with the correct paperwork and they decided that some of the paperwork i submitted on my first attempt was sufficient on the first attempt but when they received it on my second attempt it was now not sufficient. FFS!!! The same friken paperwork!!!
They have now done this 4 times which shows quite a bit of incompetence which has wasted a lot of my time.
Anyway.......... i just need to pass the partial inspection. Please help.
sabian92
PostPosted: 21:35 - 04 Jan 2015    Post subject: Reply with quote
And importing one when you could have bought a UK spec one isn't?
Bikeless
PostPosted: 21:36 - 04 Jan 2015    Post subject: Reply with quote
Stickers on clocks,modify headlight bracket.
monkeybiker
PostPosted: 21:42 - 04 Jan 2015    Post subject: Reply with quote
Mph sticker on clock.
Stickers on the clocks is not MSVA compliant. Changing the beam of the whole headlight is also not likely compliant.
ian505050
PostPosted: 21:46 - 04 Jan 2015    Post subject: Reply with quote
The bike was cheap and i read all the DVLA paperwork stating the requirements i had to complete before buying the bike. I was happy to accept that and follow the process and cost involved to register the bike.
I was not expecting the DVLA to be as slack as they seem to be with this type of thing. Its almost as if they do understand there own system which has wasted so much of my time.
I have £500 to play with before i would consider the bike as a bad buy TBF.
Bikeless
PostPosted: 21:51 - 04 Jan 2015    Post subject: Reply with quote
Is this a new law,when I bought a Jap 400 in 1998,it was taken from the container,mot'd and I was sent on my way with a Jap logbook.
PostPosted: 21:56 - 04 Jan 2015    Post subject: Reply with quote
Several times. I have got bikes through the old system with a kmh speedo with no problems, but now on a newer bike it needs to go through msva, and that requires the mph markings to be permanent
Bikeless
PostPosted: 21:58 - 04 Jan 2015    Post subject: Reply with quote
Ahh right,didn't know that Thumbs Up
ian505050
aye, i agree with that. That was my initial plan with the speedo.
I might give the inspection centre a call and ask what they think is sufficient.
ian505050
PostPosted: 22:00 - 04 Jan 2015    Post subject: Reply with quote
I am struggling to find crash damaged UK spec CBF Speedometers. I am keeping my fingers crossed that someone stacks there CBF250 soon. #truebikerspirit
PostPosted: 22:05 - 04 Jan 2015    Post subject: Reply with quote
There are people around who can supply a new face for the speedo. Note that technically to be UK legal it must show mph and kmh (although don't think msva test is quite that pedantic).
i.p.phrealy
PostPosted: 22:10 - 04 Jan 2015    Post subject: Reply with quote
Can you not get a generic headlight for £20 off ebay?
wr6133
PostPosted: 22:30 - 04 Jan 2015    Post subject: Reply with quote
Any reason you can't use a MPH converter? https://www.ebay.co.uk/itm/Motrax-Mechanical-Speedo-Cable-Converter-KPH-to-MPH-Speedo-NEW-FREEPOST-/151522140722?pt=UK_Motorcycle_Parts_13&hash=item23476c6232
If the clock markings matter open them up and stick MPH over the KPH
Wonko The Sane
PostPosted: 00:14 - 05 Jan 2015    Post subject: Reply with quote
Should be able to find a headlight similar size and a bit of modification to the brackets and it'll fit.
Might be an opportunity to upgrade to a better headlight.
onefourk
PostPosted: 01:33 - 05 Jan 2015    Post subject: Reply with quote
This. From the pics the headlight looks like a standard 7" one that's used on a ton of cars like original Mini's and pop up headlight MX-5's, amongst other things.
PostPosted: 11:44 - 05 Jan 2015    Post subject: Reply with quote
I wonder, does the speedo have to work or be in any way accurate for the MVSA test?
Thumbs Up to actually just asking DVSA Darren.
ian505050
PostPosted: 00:22 - 11 Jan 2015    Post subject: Reply with quote
Right I have been thinking about the speedo and think that this would meet the test requirements. I have seen these for as little as £6.00 in the KPH version but unfortunately for me it seems to be quite a bit more expensive in the MPH version, but still not silly money.
I would simply need to remove the speedo cable from OEM clocks fitted to the bike and plug it into the after market one shown in the link. I am just wondering how the MPH clocks in the link would be calibrated?
https://www.ebay.co.uk/itm/MINI-MECHANICAL-CHROME-SPEEDO-65mm-MPH-Motorcycle-Streetfighter-Custom-ATV-FP-/171552694205?pt=UK_Motorcycle_Parts_13&hash=item27f1565fbd
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%203/SpeedoRequirments_zps83feb969.jpg
ian505050
PostPosted: 00:26 - 11 Jan 2015    Post subject: Reply with quote
For the headlight i have decided to go with changing the headlamp internals to correct the headlight aim.
Fingers crossed the link below does the job for £20 as its ordered now.
https://www.ebay.co.uk/itm/301320088181?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
ian505050
PostPosted: 00:39 - 11 Jan 2015    Post subject: Reply with quote
So the photo below is the current headlight which deflects light into oncoming traffic.
https://i267.photobucket.com/albums/ii302/ian505050/ian505050005/DSC04155_zpsce71647a.jpg
I aimed the light against the garge door and noticed that it seems to flick the light up a bit on the RHS which would obviously blind oncoming drivers.
https://i267.photobucket.com/albums/ii302/ian505050/ian505050005/DSC04157_zpsc9e3de61.jpg
PostPosted: 09:39 - 11 Jan 2015    Post subject: Reply with quote
Acceptable patterns for an MOT:
https://www.motuk.co.uk/images/lights_diagram1.gif
https://www.motuk.co.uk/images/lights_diagram2.gif
PostPosted: 12:06 - 11 Jan 2015    Post subject: Reply with quote
Probably, but remember you will need to remove the kmh note on the clock face.
ian505050
PostPosted: 16:05 - 12 Jan 2015    Post subject: Reply with quote
My response with regards to the after market speedometer
https://www.ebay.co.uk/itm/Mini-Universal-Black-Motorcycle-Mechanical-140-MPH-Speedo-Speedometer-Gauge-2-1-/161541094949?pt=Motorcycles_Parts_Accessories&hash=item259c997e25
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%203/Speedoreply_zpsf570eb09.jpg
Cant believe it does not need to be calibrated!!! Does that not defeat the whole point of me fitting MPH clocks instead of KPH clocks!
wr6133
PostPosted: 16:09 - 12 Jan 2015    Post subject: Reply with quote
Any reason you can't just fit the MPH converter I linked earlier? Would just need to open the clock and stick "MPH" over the KPH then
PostPosted: 16:30 - 12 Jan 2015    Post subject: Reply with quote
This whole ordeal can be sorted by quick whacking on a MPH speedo disk... just take yours out, scan 1:1, change KMH to MPH, print and refit.
Light, fit Bandit one.
The last post was made 11 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 136.36 Kb
