| ian505050 |
 ian505050 Traffic Copper
 Posted: 21:31 - 04 Jan 2015 Post subject: Speedometer requirements and headlight requirements |
I have a Honda CBF250 2007 that i have imported from Spain and i have gone through all the stages required to register it in the UK.
My final requirement now is to put the bike through Partial Vehicle inspection and a DVSA center costing £12.00.
The Partial test will only check the bikes speedometer shows MPH and the headlight aim is correct.
Currently the Speedometer is in KPH only as pictured below and the headlight is set up for use in Spain so it points at on coming traffic .
Below is a link to the requirements for the speedometer (section 4) and headlight (section 6)
https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/366046/msva-manual.pdf
1.) So......... I am thinking as personally i don't mind the clocks showing KPH would i be able to pass the test by fitting a cycle computer with permanently lit up display capable of showing speeds up to 99MPH? The Max speed of the bike in the manual is 80MPH?
https://i267.photobucket.com/albums/ii302/ian505050/ian505050004/20140913_153905_zps089efd91.jpg
2.) Can i fit some form of stick on headlight deflector? Like the ones you get on cars? I can find any specific bike light deflector?
https://i267.photobucket.com/albums/ii302/ian505050/ian505050004/20140913_153841_zpse8108be1.jpg
The sensible option and most expensive option would be to buy a UK spec headlight costing £50 ish plus fitting and find a crash damaged CBF250 and steal the MPH insert out of the clocks and replace my KPH insert that sits behind the speedo gauge. But that's a ball ache.
oh........... a snap of the bike in question
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%203/20141002_192543_zps888ba059.jpg
Its taken 20 different pieces of paperwork to try and get the DVLA to issue me with a V5 and 4 separate attempts applying for the V5 and each time i have had a response they have sent me a couple of different reasons why my application has been rejected.
I sent the first batch of paperwork off knowing it would not be sufficient and they gave me a list of bullet points stating what they needed from me. I responded with the correct paperwork and they decided that some of the paperwork i submitted on my first attempt was sufficient on the first attempt but when they received it on my second attempt it was now not sufficient. FFS!!! The same friken paperwork!!!
They have now done this 4 times which shows quite a bit of incompetence which has wasted a lot of my time.
Anyway.......... i just need to pass the partial inspection. Please help.
| sabian92 |
 sabian92 World Chat Champion
 Posted: 21:35 - 04 Jan 2015 Post subject: |
And importing one when you could have bought a UK spec one isn't? |
| Bikeless |
 Bikeless World Chat Champion
| monkeybiker |
 monkeybiker World Chat Champion
| Kickstart |
 Kickstart The Oracle
| ian505050 |
| Bikeless |
| Kickstart |
| Bikeless |
| ian505050 |
| ian505050 |
| Kickstart |
| i.p.phrealy |
 i.p.phrealy World Chat Champion
| wr6133 |
 wr6133 World Chat Champion
 Posted: 22:30 - 04 Jan 2015 Post subject: |
| Wonko The Sane |
 Wonko The Sane World Chat Champion
| onefourk |
 onefourk Two Stroke Sniffer
| Rogerborg |
 Rogerborg nimbA
 Posted: 11:44 - 05 Jan 2015 Post subject: |
I wonder, does the speedo have to work or be in any way accurate for the MVSA test?
to actually just asking DVSA Darren. ____________________ Biking is 1/20th as dangerous as horse riding.
| ian505050 |
| ian505050 |
| ian505050 |
| Rogerborg |
 Rogerborg nimbA
| Kickstart |
| ian505050 |
| wr6133 |
| P.addy |
 P.addy Red Rocket
The last post was made 11 years, 276 days ago. Instead of replying here, would creating a new thread be more useful? |
