Not bike related.. small lathe or mini mill?
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3, 4  Next
kramdra
PostPosted: 21:43 - 10 Aug 2015    Post subject: Not bike related.. small lathe or mini mill? Reply with quote
I intend to buy this.. its going to save me money over having parts made (which is bloody expensive!) and a lot of time over trying to bodge with wrong tools (a cheap hand drill is not a lathe.. bearings fucked ). ***
https://www.ebay.co.uk/itm/360344827331
A small lathe should be able to do most things I want. A mill would have some advantages and be easier to set up and use? but lack screw cutting. The above looks like one of the better ones available?
(budget under £1000 inc tooling, to fit on decent sized bench and be moveable by me, without help)
*** I will probably end up with less spare time and money Laughing
SQL
PostPosted: 21:46 - 10 Aug 2015    Post subject: Reply with quote
For that price I would be getting a older 2nd hand lathe.
kramdra
PostPosted: 22:11 - 10 Aug 2015    Post subject: Reply with quote
I assume you mean english? the problem with those is most are very big and heavy. The ones that are not are usually imperial gears/lead screw or very far away...
Alternatively Im tempted to buy a headstock, and XY table and some suitable lumps of metal for a Z column and other fixtures. I like the idea this would let me do in-place removal of things like exhaust studs..
https://www.amadeal.co.uk/acatalog/Headstock-Assembly-for-CJ18-Series-AMA_SP_CJ18_013CRB.html#SID=299
SQL
PostPosted: 22:26 - 10 Aug 2015    Post subject: Reply with quote
Not necessary English, depends on the application, if it was me I would want the best 2nd hand lathe I could get for £450.
if you want to use it for essentially a big drill then fair enough. I would be looking at something like this if it was me.
Taught2BCauti...
PostPosted: 23:09 - 10 Aug 2015    Post subject: Re: Not bike related.. small lathe or mini mill? Reply with quote
£205 postage though - that makes it a ripoff for sure.
Have you had a look at the Unimat 6 in 1?
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
MCN
PostPosted: 23:24 - 10 Aug 2015    Post subject: Reply with quote
You can do almost any milling work in a lathe too.
Use your head.
Karma
kramdra
PostPosted: 23:58 - 10 Aug 2015    Post subject: Reply with quote
Too big, perhaps not so bad without the cabinet but its got a pretty massive motor and pulley system inside. Also collection only from swansea...
This will mostly live in upstairs spare room, which is not ideal Laughing
£205 postage? where do you see that.
Unimat?!? I think they are made mostly of plastic Laughing would take me 10 seconds to break it, hand drill would do a better job.
https://www.ebay.co.uk/itm/131292579091
Carriage is free to most of UK mainland (but excludes Northern Ireland, Islands & several Scottish postcode areas). Next working day when ordered before 1pm! For customers in Northern Ireland shipping will be £40. Please select the £40 option when buying this item.
PostPosted: 06:05 - 11 Aug 2015    Post subject: Reply with quote
That machine is junk. You'll find that the gib on the cross-slide doesn't fit properly, it allows the slide to lift and causes chatter and poor finish. They also have a habit of stripping gears and burning out motor controllers.
c_dug
PostPosted: 08:04 - 11 Aug 2015    Post subject: Reply with quote
A lathe is far more versatile than a mill.
We have a bunch of lathes from the sixties and seventies in our workshop and two of six are in metric, old lathes aren't necessarily in Imperial.
I've never used a new lathe, but our new Mill isn't up to the standard of the old bridgeports despite them having 30 years of use on them and mostly sits there unused.
Basically I'd go for an old Colchester lathe if I needed one.machine.
Taught2BCauti...
PostPosted: 09:14 - 11 Aug 2015    Post subject: Reply with quote
I swear it said £205 postage when I looked last night Embarassed
It does look like a re-badged Clarke or Sealey though - and you might be right about the hand drill - the motor is only 550W.
I am looking for something similar at the moment, but I don't think this would be powerful enough.
Fizzer Thou
PostPosted: 10:20 - 11 Aug 2015    Post subject: Reply with quote
I would go for a Myford ML7.I have one and it is worth its weight in titanium Wink
https://www.myford-lathes.com/used.htm
Always have a 'Plan B'
kramdra
PostPosted: 10:38 - 11 Aug 2015    Post subject: Reply with quote
I'm aware of the issues, but for the price it seems decent, with a time consuming possibility for many improvements..
Can suggest something else? this place is not far..
https://www.gandmtools.co.uk/shop/drummond-m-type-3-12-lathe-no-motor-80202370/
However I think that is probably much, much larger than it looks Shocked
Another one, but too far...
https://www.ebay.co.uk/itm/281645919807
c_dug
PostPosted: 11:00 - 11 Aug 2015    Post subject: Reply with quote
The Drummond one won't be that big, the table will be at roughly waist height, and it's taller than it is long.
kramdra
PostPosted: 11:02 - 11 Aug 2015    Post subject: Reply with quote
Its not so much about power, most small lathes will be similar.. Rigidity of machine is far more important - and something the Chinese ones are known to be lacking, but probably adequate for me.. the bed only weighs 13kg Laughing
My issue is the limited space, if your able, get the heaviest thing you can find. Sealey and clarke, draper, silverline etc.. are big brands that do not make a single thing themselves.
It is very important not to "over-motor" a Myford (or indeed any other lathe); any accident or dig in will have far more serious consequences - and if the machine is worked beyond its capacity, excessive wear will occur. Early ML7s were fitted with 1/3 hp motors, later ones with 1/2 hp - the latter a figure that should not be exceeded. Apart from the very first examples, the Super 7 has always been equipped with a 0.75 hp motor (necessary to pull the top speed of over 2000 rpm) and this too should be respected as an absolute maximum.
PostPosted: 16:54 - 11 Aug 2015    Post subject: Reply with quote
That M type is three times more than it's worth. I sold my dad's one with motor, bench and a stack of tools for £200 ish
https://youtu.be/-IatwoA00E0?t=8m51s
PostPosted: 20:25 - 11 Aug 2015    Post subject: Reply with quote
Granville lathe in Woking. Probably 3 times the weight of that noodle and not metric but what a nice machine. Inside, outside and soft jaws on a Pratt chuck, that's got to be worth near the current bid price.
https://r.ebay.com/ycPwyw
kramdra
PostPosted: 01:17 - 13 Aug 2015    Post subject: Reply with quote
I did not see your post in time to buy it Sad I had looked through most of ebay, many, many pages Shocked annoyed I did not see it.
Im going to assume I could learn to live with inches or replace the leadscrew to convert to metric.. seems gear sets would be very similar just different combinations.
https://www.ebay.co.uk/itm/220578592496
too far Sad
https://www.ebay.co.uk/itm/171883565768
https://www.ebay.co.uk/itm/261991404906
Near... looks worn for the price.
https://www.ebay.co.uk/itm/151752506641
c_dug
PostPosted: 06:09 - 13 Aug 2015    Post subject: Reply with quote
What do you actually plan on doing so often that metric screw cutting is a deciding factor?
For almost every job I've done in the last two and a half years a tail stock die holder has been more than adequate.
kramdra
PostPosted: 21:41 - 13 Aug 2015    Post subject: Reply with quote
Perhaps not often but I would like to be able to cut large threads, 30mm+
Im also going to need a vertical slide, 4 jaw chuck, collets etc.. where to buy from - none are cheap on ebay, any good shops?
Ive got some tool bits, 3/8", 1/2.. then some massive 1" and 2" x6" lumps of HSSco. Some are ground others plain. So hoping I dont need to buy much.
PostPosted: 21:48 - 13 Aug 2015    Post subject: Reply with quote
There's a Warco 300 on Gumtree. It's a bit limiting in it's work envelope because of the cross-slide table but it does double-up as a milling machine, of sorts.
https://www.gumtree.com/p/lathes/for-sale/1128357888
One of these just today sold for £840 on eBay.
Sload
PostPosted: 22:28 - 13 Aug 2015    Post subject: Reply with quote
With the not often factor incorporated, couldn't you just say occasionally you may need to source things externally rather then fabbing everything yourself?
After watching https://www.youtube.com/user/colinfurze that dude cause havok I'm starting to itch to get something myself for a play as my skillset is similar if just not developed with machining. Fortunately the guy I was going to pester has already replied to you Mr. Green
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
PostPosted: 20:32 - 14 Aug 2015    Post subject: Reply with quote
ML4 in Luton currently very cheap. I know it's old and it looks rusty but it would clean up to work better than that noodle and hasn't been butchered. Apparently has all it's changewheels, original paint and for a bonus it will cut both Metric and English threads.
https://r.ebay.com/WxdE2Y
kramdra
PostPosted: 23:53 - 16 Aug 2015    Post subject: Reply with quote
The ml4 went very cheap but too far for me... nothing close enough and really dont care to hire a van and collect. I want it delivered Laughing
Im probably going to get one of the 10x16 chinese ones with MT4 spindle.. 120-150kg and perfect size.
kramdra
PostPosted: 23:15 - 19 Aug 2015    Post subject: Reply with quote
Had a look at these today, probaby ordering something for Saturday delivery Very Happy
The smaller machines, 7-14, 8-16 are tiny Shocked
https://www.warco.co.uk/metal-lathes-metalworking-lathe-machine/16-wm-240-variable-speed-lathe.html
https://www.warco.co.uk/metal-lathes-metalworking-lathe-machine/17-wm-250-variable-speed-lathe.html
They look good. I like the 250 other than bed is a bit too long. Trying to decide.. main difference is extra 100 quid for the bigger spindle and longer bed, 200w more motor..
Spec and bits included are quite a bit better than the amadeal version.
PostPosted: 23:27 - 19 Aug 2015    Post subject: Reply with quote
250 has leadscrew reverse too.
Gear-head machine here not too far from you.
https://r.ebay.com/sXJNu1
The last post was made 11 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 138.05 Kb
