| kramdra |
 kramdra World Chat Champion
 Posted: 21:43 - 10 Aug 2015 Post subject: Not bike related.. small lathe or mini mill? |
I intend to buy this.. its going to save me money over having parts made (which is bloody expensive!) and a lot of time over trying to bodge with wrong tools (a cheap hand drill is not a lathe.. bearings fucked ). ***
https://www.ebay.co.uk/itm/360344827331
A small lathe should be able to do most things I want. A mill would have some advantages and be easier to set up and use? but lack screw cutting. The above looks like one of the better ones available?
(budget under £1000 inc tooling, to fit on decent sized bench and be moveable by me, without help)
*** I will probably end up with less spare time and money  |
| SQL |
 SQL World Chat Champion
| kramdra |
 Posted: 22:11 - 10 Aug 2015 Post subject: |
I assume you mean english? the problem with those is most are very big and heavy. The ones that are not are usually imperial gears/lead screw or very far away...
Alternatively Im tempted to buy a headstock, and XY table and some suitable lumps of metal for a Z column and other fixtures. I like the idea this would let me do in-place removal of things like exhaust studs..
https://www.amadeal.co.uk/acatalog/Headstock-Assembly-for-CJ18-Series-AMA_SP_CJ18_013CRB.html#SID=299 |
| SQL |
 Posted: 22:26 - 10 Aug 2015 Post subject: |
Not necessary English, depends on the application, if it was me I would want the best 2nd hand lathe I could get for £450.
if you want to use it for essentially a big drill then fair enough. I would be looking at something like this if it was me. |
| Taught2BCauti... |
 Posted: 23:09 - 10 Aug 2015 Post subject: Re: Not bike related.. small lathe or mini mill? |
| kramdra wrote: | I intend to buy this.. its going to save me money over having parts made (which is bloody expensive!) and a lot of time over trying to bodge with wrong tools (a cheap hand drill is not a lathe.. bearings fucked ). ***
£205 postage though - that makes it a ripoff for sure.
Have you had a look at the Unimat 6 in 1? ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| MCN |
 MCN Super Spammer
 Posted: 23:24 - 10 Aug 2015 Post subject: |
You can do almost any milling work in a lathe too.
Use your head.
| kramdra |
 Posted: 06:05 - 11 Aug 2015 Post subject: |
That machine is junk. You'll find that the gib on the cross-slide doesn't fit properly, it allows the slide to lift and causes chatter and poor finish. They also have a habit of stripping gears and burning out motor controllers. ____________________ a.k.a 'Geri'
| c_dug |
 c_dug Super Spammer
| Taught2BCauti... |
 Posted: 09:14 - 11 Aug 2015 Post subject: |
I swear it said £205 postage when I looked last night
It does look like a re-badged Clarke or Sealey though - and you might be right about the hand drill - the motor is only 550W.
I am looking for something similar at the moment, but I don't think this would be powerful enough. ____________________ Honda Varadero XL125(V8)
| Fizzer Thou |
 Posted: 10:20 - 11 Aug 2015 Post subject: |
I would go for a Myford ML7.I have one and it is worth its weight in titanium
https://www.myford-lathes.com/used.htm ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| kramdra |
| c_dug |
 c_dug Super Spammer
| kramdra |
 Posted: 11:02 - 11 Aug 2015 Post subject: |
| Taught2BCautious wrote: | I swear it said £205 postage when I looked last night
I am looking for something similar at the moment, but I don't think this would be powerful enough. |
Its not so much about power, most small lathes will be similar.. Rigidity of machine is far more important - and something the Chinese ones are known to be lacking, but probably adequate for me.. the bed only weighs 13kg
My issue is the limited space, if your able, get the heaviest thing you can find. Sealey and clarke, draper, silverline etc.. are big brands that do not make a single thing themselves.
| Quote: | It is very important not to "over-motor" a Myford (or indeed any other lathe); any accident or dig in will have far more serious consequences - and if the machine is worked beyond its capacity, excessive wear will occur. Early ML7s were fitted with 1/3 hp motors, later ones with 1/2 hp - the latter a figure that should not be exceeded. Apart from the very first examples, the Super 7 has always been equipped with a 0.75 hp motor (necessary to pull the top speed of over 2000 rpm) and this too should be respected as an absolute maximum. |
 Posted: 20:25 - 11 Aug 2015 Post subject: |
Granville lathe in Woking. Probably 3 times the weight of that noodle and not metric but what a nice machine. Inside, outside and soft jaws on a Pratt chuck, that's got to be worth near the current bid price.
https://r.ebay.com/ycPwyw ____________________ a.k.a 'Geri'
| kramdra |
| c_dug |
 c_dug Super Spammer
| kramdra |
 Posted: 21:48 - 13 Aug 2015 Post subject: |
There's a Warco 300 on Gumtree. It's a bit limiting in it's work envelope because of the cross-slide table but it does double-up as a milling machine, of sorts.
https://www.gumtree.com/p/lathes/for-sale/1128357888
One of these just today sold for £840 on eBay. ____________________ a.k.a 'Geri'
| Sload |
 Sload World Chat Champion
 Posted: 20:32 - 14 Aug 2015 Post subject: |
ML4 in Luton currently very cheap. I know it's old and it looks rusty but it would clean up to work better than that noodle and hasn't been butchered. Apparently has all it's changewheels, original paint and for a bonus it will cut both Metric and English threads.
https://r.ebay.com/WxdE2Y ____________________ a.k.a 'Geri'
| kramdra |
 Posted: 23:53 - 16 Aug 2015 Post subject: |
The ml4 went very cheap but too far for me... nothing close enough and really dont care to hire a van and collect. I want it delivered
Im probably going to get one of the 10x16 chinese ones with MT4 spindle.. 120-150kg and perfect size. |
| kramdra |
 Posted: 23:27 - 19 Aug 2015 Post subject: |
250 has leadscrew reverse too.
Gear-head machine here not too far from you.
https://r.ebay.com/sXJNu1 ____________________ a.k.a 'Geri'
The last post was made 11 years, 28 days ago. Instead of replying here, would creating a new thread be more useful? |
