ER6-F Electrical Issue
LukeD1357
PostPosted: 13:39 - 29 Sep 2015    Post subject: ER6-F Electrical Issue Reply with quote
Hi all,
Bought an ER6-F 2009 before I'd passed my test but I stuck to starting it every day and leaving it to idle for a few minutes.
I forgot to do this for around a month, went to start it and nothing happened, turning the key didn't do anything, none of the dash lit up or anything.
I jumped it using jump leads and it started fine, but as soon as you took the leads off, it died.
So I presumed it was the battery, I then bought a brand new battery, charged it overnight and then tried it. Still nothing happened.
Any ideas what this could be? I've checked all the fuses, but now even using jump leads doesn't do anything.
Thanks in advance.
PostPosted: 15:39 - 29 Sep 2015    Post subject: Re: ER6-F Electrical Issue Reply with quote
If you were trying to run the battery down then that was the way to do it.
Did you test it / have you now tested it with a volt/multimeter to see what voltage it showed?
Did you connect it up the right way around?
Are you sure?
PostPosted: 15:54 - 29 Sep 2015    Post subject: Reply with quote
What actually happens when you turn the ignition on?
LukeD1357
PostPosted: 16:58 - 29 Sep 2015    Post subject: Reply with quote
Nothing happens at all when you turn the ignition, nothing lights up, no noises or anything, its as if its not connected. And I was starting it daily to make sure it didn't seize up or anything. And yes its definitely connected the right way
PostPosted: 17:17 - 29 Sep 2015    Post subject: Reply with quote
Kill switch?
Robby
Dirty Old Man
PostPosted: 17:23 - 29 Sep 2015    Post subject: Reply with quote
If you separate out the two incidents (starting/idling/starting and fitting a new battery), then the most logical problem is a blown fuse. Either the main 30A one on the starter relay near the battery, or one of the others in the fuse box wherever that lives.
Nothing in the description of the problem gives a reason for anything going wrong. Starting and idling is pointless, but won't cause any significant problems. Jump starting is fine, despite tales of woe from 16 year olds thinking that must be the reason their ped is fucked. Charging a new battery overnight is the correct thing to do, and fitting it the wrong way round is difficult on most bikes - the leads won't reach the terminals.
However, leave a bike for a month or 12, fit a new battery and try starting, and sometimes a fuse will blow. I've had it happen to me.
You've done more harm than good starting it.... take battery off and leave it charging.
My bike hadn't been started for 2 months and it fired up today and got ragged silly. You've got it a bit warm and shut it off. Engines wear faster when cold....constantly doing that is gonna break something.
Robby
Dirty Old Man
PostPosted: 17:28 - 29 Sep 2015    Post subject: Reply with quote
It would take a very long time to break something. You might cause a mild steel exhaust part to rust out in 9 years instead of 10. You might cause a bit more wear on the mains so they are worn out at 220k instead of 250k.
Very few bikes are going to live long enough for little things like this to be an issue. They get crashed, nicked, run out of oil or sold to Iain first.
PostPosted: 17:40 - 29 Sep 2015    Post subject: Reply with quote
So you reckon if I start my bike for 5 minutes every day and just leave it all will be well?
LukeD1357
PostPosted: 18:06 - 29 Sep 2015    Post subject: Reply with quote
I checked all the fuses in the fuse box, and they are all fine, I have not checked the one you mentioned as I didn't see it, I will see if that's the problem. I really hope so, otherwise to the garage it goes.
wots
PostPosted: 18:21 - 29 Sep 2015    Post subject: Reply with quote
It's the main fuse. Left hand side with the relay. Mine died on a ride, all fine then just popped. Take off the seat, the left side panel black thing and it's between the two rails in the frame. It's not with the fuses in the fuse box.
EDIT: If you don't know your left from your right (I didn't when I started was used to offside nearside), it's the opposite side to the fuse box.
LukeD1357
PostPosted: 18:22 - 29 Sep 2015    Post subject: Reply with quote
And the people saying that starting it everyday is bad, when I am unable to ride it, what do you suggest I do? Let it sit there and not start it at all?
PostPosted: 18:27 - 29 Sep 2015    Post subject: Reply with quote
Yes. Put it on an optimate if it is going to be like that for more than a month.
PostPosted: 18:28 - 29 Sep 2015    Post subject: Reply with quote
Sure. Keep the tank full, keep the battery charged, put it on the centre stand, on a block of wood if you like to get the pressure off the tyres. It's not going to seize solid over a few months.
If it's not the main fuse, do yourself a favour and buy a cheap multimeter. It's far, far cheaper and quicker than guessing.
wots
Starting every day is pointless, starting once a week or once a fortnight maybe. My ER-6F can go for weeks without being started. I start, jump on and ride (no warmup) always without issue. Haven't ridden my fireblade in 3-4 weeks. Can all but guarantee I can go and ride it right now in the same way. The ONLY thing IMO that needs care is the battery and start and idle won't actually condition that, as the bike needs to be at a minimum 4K for 10-15 minutes to keep it topped up with what's used from starting from cold.
PostPosted: 18:32 - 29 Sep 2015    Post subject: Reply with quote
Sure, an Enfield may not have a temperature readout or a gear indicator or service light or a fuel gauge or a trip meter, but by God it's got an ammeter that shows how long it takes to recover the energy used in giving it an electric kick.
One day everyone will catch on. Whistle
Robby
Dirty Old Man
PostPosted: 18:48 - 29 Sep 2015    Post subject: Reply with quote
Yes, unless it's something ultra fragile.
PostPosted: 18:54 - 29 Sep 2015    Post subject: Reply with quote
I'm willing to give it a go...With a 125. I'll buy one at end of the year Thumbs Up
LukeD1357
PostPosted: 19:02 - 29 Sep 2015    Post subject: Reply with quote
She's alive, main starter fuse had blown, thanks a lot guys.
The last post was made 10 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 103.3 Kb
