Ground anchor.
Saraya
PostPosted: 10:20 - 16 May 2016    Post subject: Ground anchor. Reply with quote
Before I make another newbie error, like my previous Oxford security purchases – I want to check with you guys. Is this ok for a ground anchor?
https://www.amazon.co.uk/Mammoth-grd003-Concrete-In-Ground-Anchor/dp/B004FS0Z58/ref=sr_1_3?ie=UTF8&qid=1463389812&sr=8-3&keywords=motorcycle+ground+anchor
If not, would you please recommend another? It’s got to be a stuff in wet concrete one and not a screw down one. And also, it can’t be brightly coloured as it’s sort of being hidden in a hedge. (Don’t ask!)
Thank you. Smile
Andy_Pagin
PostPosted: 10:53 - 16 May 2016    Post subject: Reply with quote
Depends what it's made from, could it resist a bolt cropper or angle grinder?
Also the hoop looks a bit small to me, would it take the chain you're going to use?
mrbox
Wonderwall
PostPosted: 11:06 - 16 May 2016    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Heavy-duty-90mm-motorcycle-ground-anchor-Almax-IV-compatible-100-British-Made-/291750638185?hash=item43edb17269:g:NroAAOSwFqJWoIwS
just picked up one of these the are a flush fit to the ground
Current bikes: RE Himalayan, Bandit 12, MZ250ES
PostPosted: 11:13 - 16 May 2016    Post subject: Reply with quote
mrbox wrote:
Want that one.
The eye-bolt ones have tight ringpieces steady but if you can't get a 16mm/19mm chain through it, you might as well not bother.
JoeDaStudd
PostPosted: 11:16 - 16 May 2016    Post subject: Reply with quote
I've probably go with a Y anchor or one of the Pragmasis anchors.
Just make sure it can take upto a 16mm/19mm chain.
Saraya
PostPosted: 11:36 - 16 May 2016    Post subject: Reply with quote
If I get the one from Ebay that Mrbox posted - is the right stuff to stick it in? And do you think one bag would be enough? Sorry to be a pest. Hubby is worse at DIY than I am, so there's no point asking him!
https://www.homebase.co.uk/en/homebaseuk/postmix-concrete---20kg-747697
Thanks again people. Smile
alanstott21
PostPosted: 11:53 - 16 May 2016    Post subject: Reply with quote
I bought this one https://www.bulldogmcs.co.uk/#!product-page/zgpj2/65ec7d20-0723-8952-7b8a-c10a86096744
BakesBeans
PostPosted: 13:08 - 16 May 2016    Post subject: Reply with quote
I put one of those in at weekend, it's big bastard under the surface. To answer your question, it really does depend how big a hole you dig!
I used one bag of cement, 1 sharp sand, 1 builders sand and 1 gravel. It worked out cheaper than postcrete and I did mix it a little stronger too! I used the builders sand in the last top mix to make it look nice.
I did cement in a washing line pole too though...
I did have some sand left, as intended, to place slabs down neatly...
Current: Kawasaki ZX636
Previous Bike: Honda CBR600F ABS, Yamaha XJ6 F Diversion ABS, Honda VFR400 NC30
Commuter_Tim
PostPosted: 15:41 - 16 May 2016    Post subject: Reply with quote
Whilst mostly true, one of these solves that problem.
To OP: Chain through the bike, anti pinch pin with squire lock at the anchor end.
I ride a Bandit 600... badly.
PostPosted: 16:10 - 16 May 2016    Post subject: Reply with quote
That's the stuff, if you don't want to be messing around with separate bags of sand and cement. As to sizing, I'd err on two bags for a few £££ difference and dig a large hole - it's the mass of cement that's going to keep it in place.
Dave70
PostPosted: 18:08 - 16 May 2016    Post subject: Reply with quote
Just to deviate slightly.
Are ground anchors just as effective if they are put into a brick wall or is it largely a waste of time?
mrbox
Wonderwall
PostPosted: 18:38 - 16 May 2016    Post subject: Reply with quote
I would suggest not as secure.
mrbox
Wonderwall
PostPosted: 18:40 - 16 May 2016    Post subject: Reply with quote
you can use some old bricks as filler if you dig too big a hole Thumbs Up I always end up with a slack hole every bloody time Laughing
PostPosted: 18:44 - 16 May 2016    Post subject: Reply with quote
I wouldn't. Laughing
How effective it'll be at making your house fall down should someone remove the ground anchor from the wall will depend on how important the wall you use is. Thumbs Up
Dave70
PostPosted: 19:19 - 16 May 2016    Post subject: Reply with quote
Yeah, I think I'll scrap the wall idea. Laughing
ADSrox0r
PostPosted: 19:25 - 16 May 2016    Post subject: Reply with quote
Lump hammer and a cold steel chisel. Or a battery SDS and it's out in no time.
Andy_Pagin
PostPosted: 20:47 - 16 May 2016    Post subject: Reply with quote
I've used that stuff for fence posts, you tip sack in the hole around the post, add water as per the instructions and it sets perfectly. No mixing and no mess.
Saraya
PostPosted: 20:55 - 16 May 2016    Post subject: Reply with quote
Thanks again guys. Smile
Now I either have to borrow a spade from someone that knows I have no garden and explain why I'm interfering with a council (?) hedge. Or go buy one.
This biking malarkey is fun. Laughing
mrbox
Wonderwall
PostPosted: 21:02 - 16 May 2016    Post subject: Reply with quote
fence post tool ftw Thumbs Up
https://www.ebay.co.uk/itm/Fence-Post-Hole-Soil-Digger-Grabbers-Metal-Handle-Rubber-Grip-Garden-Tool-Kit-/251848265235?hash=item3aa3538e13:g:KBAAAOSweW5U5wMa
Saraya
PostPosted: 21:14 - 16 May 2016    Post subject: Reply with quote
Thank you - but I don't think I'd get it in. I'm hiding the anchor under a holly and hawthorn hedge. Not sure I can get in there with a spade either actually. I might have to spend ages with a little trowel. Sad Nearly lost an eye yesterday wrapping the chain around the holly trunk!
BTTD
PostPosted: 22:30 - 16 May 2016    Post subject: Reply with quote
Small army entrenching tool. Thumbs Up
https://en.wikipedia.org/wiki/Entrenching_tool
Also, safety glasses!
https://www.screwfix.com/p/bolle-silium-clear-lens-safety-specs/89679
Saraya
PostPosted: 08:34 - 17 May 2016    Post subject: Reply with quote
Yep. That's what I need. Thanks! Laughing
The last post was made 10 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 117.44 Kb
