Rapid Battery Drain
Bunzena
PostPosted: 11:36 - 28 Sep 2026    Post subject: Rapid Battery Drain Reply with quote
Hi. Have fitted a brand new battery as bike wouldn't start.
Voltage showing on dash as 11.9 - and this corresponded to a multimeter reading too. Was original battery - 5 years old. Always been on a tender - but ho hum.
New battery [which has been fully charged] shows initial voltage [with ignition on] as 12.6 - and bike starts. However after 5-10 minutes voltage has dropped to around 12.0 volts and bike won't turn over. Crying or Very sad
There's no apparent heavy or even parasitic drain other than the LED lights. But can't see how these would have an impact in such a short time.
My suspicion is that the Regulator/Rectifier may be kapput?
Bike is a 5 year old NC750X - low mileage.
Any thoughts on what could be happening?
Rob W
PostPosted: 13:07 - 28 Sep 2026    Post subject: Reply with quote
What does the multimeter say when the bike is running?
Bunzena
PostPosted: 13:36 - 28 Sep 2026    Post subject: Reply with quote
Thanks for response/question.
Registers around 14.4v steady.
So seems to be charging.
Haven't pulled the Reg/Rec out of the bike yet [it's in an awkward location] - so haven't tested it.
But suspicion is that the diode may have failed?
A100man
PostPosted: 15:37 - 28 Sep 2026    Post subject: Reply with quote
could be a duff new battery - does it charge off the bike?
Bunzena
PostPosted: 16:33 - 28 Sep 2026    Post subject: Reply with quote
I did think it might be the new battery - but the retailer [who was very pro-active] sent a new one I fitted this morning [after charging].
Had exactly the same issue.
When newly fitted and charged - showed a static 12.6v
After 30 minutes had fallen to 12.3v - now [6 hours later] at 12.1v
So there's a significant drain. I have heated grips and fog lights [using factory harness] - but they've been onboard for a while. The bike is garaged and has no corrosion. Earths look good.
So - and I'm guessing - the Reg/Rec may be playing up. Dodgy diode.
The Reg/Rec an absolute pig to get at. Petrol tank has to come out, rear mudguard, brake light, and multiple body panels off. Previous nakeds have always had the Reg/Rec in the airstream. Embarassed
Easy-X
PostPosted: 16:59 - 28 Sep 2026    Post subject: Reply with quote
Do you have a multimeter with a current setting? A decent one can handle 10amps but with ignition off I'd only expect 10 to 100mA. Be interesting to see what the drain is just sitting there. Also try disconnecting the reg/rec and see if it affects things.
Bunzena
PostPosted: 17:31 - 28 Sep 2026    Post subject: Reply with quote
Thanks Easy-X
My multimeter does have a current setting. But I'm not sure it's working.
With the ignition off it's not registering any drain at all.
I guess that's possible?
Getting to the Reg/Rec is a shocker - been at it an hour or so - and still not able to get access to it.
A100man
PostPosted: 18:02 - 28 Sep 2026    Post subject: Reply with quote
Bunzena wrote:
Thanks Easy-X
Not likely on a modern bike I'd think - clocks and computers need to be kept awake, no?
Can you try pulling fuses in turn to see if it helps? Those electrons must be going somewhere!
Bunzena
PostPosted: 18:55 - 28 Sep 2026    Post subject: Reply with quote
Good thinking A100man.
I have a more modern multimeter on the way that might reveal more.
In the morning - I shall start pulling fuses... Very Happy
jeffyjeff
PostPosted: 22:42 - 28 Sep 2026    Post subject: Reply with quote
Don't forget to check the fuses in your multimeter. Bridging the leads in parallel to a live circuit with the meter set to measure Amperes will blow the meter fuse instantly. As far as I know, most multimeters will not indicate a blown fuse on the meter display, and a blown fuse will prevent the meter from measuring current.
Bunzena
PostPosted: 05:44 - 29 Sep 2026    Post subject: Reply with quote
jeffyjeff wrote:
Don't forget to check the fuses in your multimeter. Contacting the leads to a live circuit with the meter set to measure Amperes will blow the meter fuse instantly. As far as I know, most multimeters will not indicate a blown fuse on the meter display, and a blown fuse will prevent the meter from measuring current.
Again - good point. Thank you.
doggone
PostPosted: 11:36 - 29 Sep 2026    Post subject: Reply with quote
If you pull the fuses in a rather dark place you will see a small spark most likely especially with a serious draw like that.
There aren't many things live with ignition off as a rule.
A100man
PostPosted: 11:43 - 29 Sep 2026    Post subject: Reply with quote
You mean lights off or a rather sombre mood?
Bunzena
PostPosted: 13:04 - 29 Sep 2026    Post subject: Reply with quote
Like that idea - very smart. Nice piece of lateral thinking.
And A100man - my mood is definitely darkening!
Bunzena
PostPosted: 14:37 - 07 Oct 2026    Post subject: Reply with quote
Problem seems to be solved.
It appears that I was sold a dud battery – and then it’s warranty replacement was little better.
Both batteries charged-up – the first quickly lost voltage and I mistakenly put that down to a drain from the bike.
The second, replacement held voltage at around 12.87 to 12.6 volts over a ten day period. But really didn’t want to crack the engine after a couple of days.
My own fault – but should have run a deeper diagnostic on the batteries. An analogue “load-type” tester showed both batteries as “weak and needing replacement”. The first more than the second.
A more sophisticated test using a friends iCarsoft rig – suggested both batteries had very low SOH and high internal resistance.
The online retailer [who I have used many times before] looked at those readings and immediately offered a full refund.
So what to do next?
Order a third one [same Yuasa brand] from the same retailer? [I have asked them to check it’s okay before despatch.]
Order another brand?
Switch to an equivalent LiPO battery?
My real issue with LiPO is that there’s no definitive answer as to whether I can jump start that with a Lithium jump pack if I get stranded. Any thoughts?
Finally thanks to all those who contributed.
jaffa90
PostPosted: 17:21 - 07 Oct 2026    Post subject: Reply with quote
Just googled ( what is a motor cycle lipo battery ) and was shocked. Shocked
My biking days are over but would not consider these.
A100man
PostPosted: 19:48 - 07 Oct 2026    Post subject: Reply with quote
Fakes ?? Can happen.
Kawasaki Jimbo
PostPosted: 21:00 - 07 Oct 2026    Post subject: Reply with quote
I was wary that a LiFePO4 might ignite and blow my balls off too but for some reason I risked it. Shocked They’re fine if you get one with a built-in battery management system (BMS). If you want to charge off the mains you’ll need a charger with a lithium mode but that’s not uncommon these days.
The weight of the battery is comically light, I really thought I’d been given an empty cardboard box. Cranking power is noticeably strong although I didn’t get the feeling it would last any longer than a lead-acid if the bike didn’t want to start. I could be wrong about that.
In the end my bike’s parasitic drain finished that battery off too despite the Li low self-discharge rate, and after finding the cause of that I went back to lead-acid, but I’d have no concerns about lithium.
jeffyjeff
PostPosted: 00:42 - 08 Oct 2026    Post subject: Reply with quote
I have had very good experiences with Yuasa batteries. If a new battery fails to crank the motor after a few days idle, but the charging system and battery no-load specs are otherwise OK, I would consider a problem in the starting circuit. Check voltage drop between the battery and starter during cranking. Check the starter current draw. Problem could be in the starter relay or wiring. If you have another bike available, try swapping batteries to see if the problem follows the battery. You might be overlooking the cause of your problem.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.9 - MySQL Queries: 13 - Page Size: 103.47 Kb
