| Bunzena |
 Bunzena Two Stroke Sniffer
 Posted: 11:36 - 28 Sep 2026 Post subject: Rapid Battery Drain |
Hi. Have fitted a brand new battery as bike wouldn't start.
Voltage showing on dash as 11.9 - and this corresponded to a multimeter reading too. Was original battery - 5 years old. Always been on a tender - but ho hum.
New battery [which has been fully charged] shows initial voltage [with ignition on] as 12.6 - and bike starts. However after 5-10 minutes voltage has dropped to around 12.0 volts and bike won't turn over.
There's no apparent heavy or even parasitic drain other than the LED lights. But can't see how these would have an impact in such a short time.
My suspicion is that the Regulator/Rectifier may be kapput?
Bike is a 5 year old NC750X - low mileage.
Any thoughts on what could be happening? |
| Rob W |
 Rob W World Chat Champion
| Bunzena |
| A100man |
 A100man World Chat Champion
 Posted: 15:37 - 28 Sep 2026 Post subject: |
could be a duff new battery - does it charge off the bike? ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Bunzena |
 Posted: 16:33 - 28 Sep 2026 Post subject: |
I did think it might be the new battery - but the retailer [who was very pro-active] sent a new one I fitted this morning [after charging].
Had exactly the same issue.
When newly fitted and charged - showed a static 12.6v
After 30 minutes had fallen to 12.3v - now [6 hours later] at 12.1v
So there's a significant drain. I have heated grips and fog lights [using factory harness] - but they've been onboard for a while. The bike is garaged and has no corrosion. Earths look good.
So - and I'm guessing - the Reg/Rec may be playing up. Dodgy diode.
The Reg/Rec an absolute pig to get at. Petrol tank has to come out, rear mudguard, brake light, and multiple body panels off. Previous nakeds have always had the Reg/Rec in the airstream.  |
| Easy-X |
 Easy-X Super Spammer
| Bunzena |
| A100man |
 Posted: 18:02 - 28 Sep 2026 Post subject: |
| Bunzena wrote: | Thanks Easy-X
With the ignition off it's not registering any drain at all.
I guess that's possible?
Not likely on a modern bike I'd think - clocks and computers need to be kept awake, no?
Can you try pulling fuses in turn to see if it helps? Those electrons must be going somewhere! ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Bunzena |
 Posted: 18:55 - 28 Sep 2026 Post subject: |
Good thinking A100man.
I have a more modern multimeter on the way that might reveal more.
In the morning - I shall start pulling fuses...  |
| jeffyjeff |
 jeffyjeff World Chat Champion
| Bunzena |
| doggone |
 doggone World Chat Champion
| A100man |
 Posted: 11:43 - 29 Sep 2026 Post subject: |
| doggone wrote: | If you pull the fuses in a rather dark place you will see a small spark most likely especially with a serious draw like that.
There aren't many things live with ignition off as a rule. |
You mean lights off or a rather sombre mood? ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Bunzena |
| Bunzena |
| jaffa90 |
 jaffa90 World Chat Champion
 Posted: 17:21 - 07 Oct 2026 Post subject: |
Just googled ( what is a motor cycle lipo battery ) and was shocked.
My biking days are over but would not consider these. |
| A100man |
 Posted: 19:48 - 07 Oct 2026 Post subject: |
| Bunzena wrote: | Problem seems to be solved.
It appears that I was sold a dud battery – and then it’s warranty replacement was little better.
Both batteries charged-up – the first quickly lost voltage and I mistakenly put that down to a drain from the bike.
The second, replacement held voltage at around 12.87 to 12.6 volts over a ten day period. But really didn’t want to crack the engine after a couple of days.
My own fault – but should have run a deeper diagnostic on the batteries. An analogue “load-type” tester showed both batteries as “weak and needing replacement”. The first more than the second.
A more sophisticated test using a friends iCarsoft rig – suggested both batteries had very low SOH and high internal resistance.
The online retailer [who I have used many times before] looked at those readings and immediately offered a full refund.
Fakes ?? Can happen. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Kawasaki Jimbo |
| jeffyjeff |
| WD Forte |
 WD Forte World Chat Champion
 Posted: 14:06 - 08 Oct 2026 Post subject: |
My Battery analyser has been a very useful tool for checking car/van/bike batteries
especially this time of year when temps drop and battery weakness can manifest itself.
A year or two ago it help prove a mates new battery didn't have anything near the cranking amps
it should have had, so a replacement was given (and immediately tested of course)
It's also useful to check if those spare batteries are worth the space they occupy and just been checking some of mine.
I keep a few old bike batteries for bench test/experimends and stuff and this one still exceeds the stated CCA so it stays
https://i.postimg.cc/YqqK9Sd0/topdon1.jpg ____________________ bikers smell of wee |
| sickpup |
 sickpup Old Timer
| Bunzena |
| Kawasaki Jimbo |
| sickpup |
 sickpup Old Timer
| Kawasaki Jimbo |
