Anyone here got an 05 DT125?
Type_Mo
PostPosted: 15:27 - 10 Jan 2006    Post subject: Anyone here got an 05 DT125? Reply with quote
How are they restricted?
How are they de-restricted?
killa
Won't Shut Up
PostPosted: 15:34 - 10 Jan 2006    Post subject: Reply with quote
Washer in down pipe, possibly.
Also factory standard DT's roll out of UK shops with the power band set to half.
If you have a friendly bike mechanic to hand, he will sort you out.
If not, www.dirtbikestore.com
Talk to them.
Andy C
Tree Seeking Missile
PostPosted: 18:07 - 10 Jan 2006    Post subject: Reply with quote
just get a crap 125 then pass your test, then spend the money you saved on a nicer 400/600/650 V-twin Laughing
i didnt do it this way but if my RS had been writting off i would haev brought/borrowed the cheapest thing to get around till pass test
buying a new DT125r would be a waste of money as you will only want a bigger bike as soon as you pass your test Thumbs Up
Type_Mo
PostPosted: 18:10 - 10 Jan 2006    Post subject: Reply with quote
gonna try n stick with the 125 for two years mate.
dad says he'll get me a brand new dt125 instead of me getting a tzr125. i think i might just buy mine back from insurance company if the price is right.
Biker-Kev
PostPosted: 18:13 - 10 Jan 2006    Post subject: Reply with quote
Do they use a powervalve?
Zhongyu ZY50, Aprilia SR50, Motorhispania RX50, Aprilia RS125, Honda VFR400 nc24 and my corsa
https://www.bikepics.com/members/bikerkev/
Theory: Passed 8/11/2005 Practical: Passed 13/12/2005 Proud holder of A2 license
J.K.R
PostPosted: 18:14 - 10 Jan 2006    Post subject: Reply with quote
Pretty sure theyve got a Powervalve Thumbs Up
r0b
PostPosted: 18:22 - 10 Jan 2006    Post subject: Re: Anyone here got an 05 DT125? Reply with quote
exhaust washer, powervalve disconnected, bigger main jet
remove exhaust washer, connect powervalve, fit correct main jet
'92 Honda NX650 Dominator RD02
'98 Kawasaki ZX9R C1
'00 Yamaha TT600R Belgarda
Rookie
PostPosted: 18:32 - 10 Jan 2006    Post subject: Reply with quote
So you binned that bike after, what, 3 weeks? And now daddy's going to buy you a new one?
Nice job... Rolling Eyes
Type_Mo
PostPosted: 18:33 - 10 Jan 2006    Post subject: Reply with quote
ive got a funni dad Exclamation
He thinks ill do worse on a sports rep, thats why he wants me to be on a trial bike.
Dom_
Points Mean Prizes
PostPosted: 19:12 - 10 Jan 2006    Post subject: Reply with quote
Theres lots of restrictions, cone in the exhaust, something in the end can is quite restrictive i'm told too. CDI is resricted. Also some sort of connector behind the headlight bulbs.
It would be easier to buy and older DT and de-res it, the new ones are a nightmare.
craigT19
Jolly Green Giant
PostPosted: 19:20 - 10 Jan 2006    Post subject: Reply with quote
any problems pm me, ive done a few of them Laughing
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
jayluvmito
PostPosted: 23:50 - 10 Jan 2006    Post subject: Reply with quote
umm, yeh. ok pal.
one day...
Dom_
Points Mean Prizes
PostPosted: 00:49 - 11 Jan 2006    Post subject: Reply with quote
craigT19 wrote:
ok first things first the 05 dt125R and the dt125x do NOT have a washer cone or any other type of contraption in the exhaust, neither are there jets or power valves restricted.
They use an electronic pulse restrictor similar to that on the old 400's to deristrict it your gunna need.
soldering iron and solder
side cutters or sum type of wire strippers.
and about 20mins of your time Laughing
heres what u do.
1. take of the bolt either side of the headlight fairing and lower the fairing forward.
2. you should see a rubber boot with a bundle of wires in it.
3. in those wires there is a large block connector, if u take it apart u will notice that there is an extra wire in the male end that dosent go anywhere (no connecting wire in the other block),
4. cut it away from the block and strip it back the solder it to a black indicator wire and put your fairing back on.
JOB DONE!!!
Cool, but why does the stock exhaust weigh so much, and why when fitting an aftermarket system does the motor seem to rev a lot more freely, and the powervalve seems more harsh when open?
jayluvmito
PostPosted: 01:47 - 11 Jan 2006    Post subject: Reply with quote
pretty sure theirs stil a restrictor inside
one day...
craigT19
Jolly Green Giant
PostPosted: 21:36 - 11 Jan 2006    Post subject: Reply with quote
no restrictors! lol just baffles and various other bits and peices made to reduce immisions Laughing
CrazyPassenge...
PostPosted: 23:53 - 05 Feb 2006    Post subject: Reply with quote
Im getting a 05 DT125X, and ive been reading 'alot' of forums about de-restricting them. Theres loads of different ways said by different ppl, but each way differs for each model of bike (90's up to 00, then 00-03, then 03 and onwards 05 etc)
Now ive finaly found out what to do with a 05 model, -
Theres the restricter behind the headlight, its a greenblack wire and all you do is earth (connect) that to the bike frame. Then theres the exhaust, its much easyer buying a full DEP system for it as its lighter aswell as de-restricted. But if you cant get one, then the only restricter in the exhaust is in the front pipe, cut the front pipe in half where the welds are, remove the two rings inside it, then re-weld! THATS IT!
There nowt you can do to the CDI, the powervalve is done when you do the gree/black wire (as the 180deg turn thing dosent apply to 05 bikes) and the only thing left is just to do a plug chop to see if you do need a bigger jet (mainly with the DEP system) but ppl mostly leave the 240 in as that tends to be ok! Wink
Thanks, rgrds Adam!
Smile Happy Days Smile Kawasaki 04 ZX10R ... an animal!
lilredmachine
PostPosted: 09:32 - 06 Feb 2006    Post subject: Reply with quote
Craig is right, the only reason they can still sell these old skool two smokes it because they carry a veritable armada of emissions gear, mainly in the exhaust. The exhaust isn't actually restricted par se, but it is overly restrictive. A dep pipe is just a can, so it has obvious advantages.
CrazyPassenge...
PostPosted: 12:41 - 06 Feb 2006    Post subject: Reply with quote
Yeh, i personally think the DEP (full) system is the best choice! As your removing a lot of weight aswell when you remove/replace the original exhaust! You can find the full DEP system at -
https://www.dirtbikestore.co.uk/acatalog/DirtBikeStore_com_DEP_Pipes_56.html
So with that fitted, and the restricter done (at the front behind the head-light) you can expect to get around 80-85mph out of it! Apart from these 'mods' im not aware of anything else to do with them Confused If anybody does know anything else, then do tell us!
Thanks, rgrds Adam!
The last post was made 20 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 103 Kb
