| Type_Mo |
 Type_Mo World Chat Champion
 Posted: 15:27 - 10 Jan 2006 Post subject: Anyone here got an 05 DT125? |
How are they restricted?
How are they de-restricted?
 ____________________ - Typhoon ?0 - Yamaha DT125R - Aprilia SR125 - Yamaha DT125R - Honda Hornet 600 - |
| killa |
 killa Won't Shut Up
| Andy C |
 Andy C Tree Seeking Missile
 Posted: 18:07 - 10 Jan 2006 Post subject: |
just get a crap 125 then pass your test, then spend the money you saved on a nicer 400/600/650 V-twin
i didnt do it this way but if my RS had been writting off i would haev brought/borrowed the cheapest thing to get around till pass test
buying a new DT125r would be a waste of money as you will only want a bigger bike as soon as you pass your test  ____________________ 99 RS125 --> 02 SV650s --> 03 Speed Four --> 92 RXS100 --> 93 CB400sf --> 01 CB600f Hornet |
| Type_Mo |
| Biker-Kev |
 Biker-Kev Brolly Dolly
 Posted: 18:13 - 10 Jan 2006 Post subject: |
Do they use a powervalve? ____________________ Zhongyu ZY50, Aprilia SR50, Motorhispania RX50, Aprilia RS125, Honda VFR400 nc24 and my corsa
https://www.bikepics.com/members/bikerkev/
Theory: Passed 8/11/2005 Practical: Passed 13/12/2005 Proud holder of A2 license |
| J.K.R |
 J.K.R World Chat Champion
 Posted: 18:14 - 10 Jan 2006 Post subject: |
Pretty sure theyve got a Powervalve  |
| r0b |
 r0b Renault 5 Driver
| Rookie |
 Rookie World Chat Champion
| Type_Mo |
 Posted: 18:33 - 10 Jan 2006 Post subject: |
ive got a funni dad
He thinks ill do worse on a sports rep, thats why he wants me to be on a trial bike. ____________________ - Typhoon ?0 - Yamaha DT125R - Aprilia SR125 - Yamaha DT125R - Honda Hornet 600 - |
| Dom_ |
 Dom_ Points Mean Prizes
| craigT19 |
 craigT19 Jolly Green Giant
 Posted: 19:20 - 10 Jan 2006 Post subject: |
any problems pm me, ive done a few of them  ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003
| jayluvmito |
 jayluvmito Crazy Courier
| Dom_ |
 Posted: 00:49 - 11 Jan 2006 Post subject: |
| craigT19 wrote: | ok first things first the 05 dt125R and the dt125x do NOT have a washer cone or any other type of contraption in the exhaust, neither are there jets or power valves restricted.
They use an electronic pulse restrictor similar to that on the old 400's to deristrict it your gunna need.
soldering iron and solder
side cutters or sum type of wire strippers.
and about 20mins of your time
heres what u do.
1. take of the bolt either side of the headlight fairing and lower the fairing forward.
2. you should see a rubber boot with a bundle of wires in it.
3. in those wires there is a large block connector, if u take it apart u will notice that there is an extra wire in the male end that dosent go anywhere (no connecting wire in the other block),
4. cut it away from the block and strip it back the solder it to a black indicator wire and put your fairing back on.
JOB DONE!!!
any problems pm me, ive done a few of them  |
Cool, but why does the stock exhaust weigh so much, and why when fitting an aftermarket system does the motor seem to rev a lot more freely, and the powervalve seems more harsh when open? |
| jayluvmito |
| craigT19 |
 Posted: 21:36 - 11 Jan 2006 Post subject: |
no restrictors! lol just baffles and various other bits and peices made to reduce immisions  ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
BCF member pops. sadly missed 1945-2003 |
| CrazyPassenge... |
 CrazyPassenge... Nitrous Nuisance
 Posted: 23:53 - 05 Feb 2006 Post subject: |
Im getting a 05 DT125X, and ive been reading 'alot' of forums about de-restricting them. Theres loads of different ways said by different ppl, but each way differs for each model of bike (90's up to 00, then 00-03, then 03 and onwards 05 etc)
Now ive finaly found out what to do with a 05 model, -
Theres the restricter behind the headlight, its a greenblack wire and all you do is earth (connect) that to the bike frame. Then theres the exhaust, its much easyer buying a full DEP system for it as its lighter aswell as de-restricted. But if you cant get one, then the only restricter in the exhaust is in the front pipe, cut the front pipe in half where the welds are, remove the two rings inside it, then re-weld! THATS IT!
There nowt you can do to the CDI, the powervalve is done when you do the gree/black wire (as the 180deg turn thing dosent apply to 05 bikes) and the only thing left is just to do a plug chop to see if you do need a bigger jet (mainly with the DEP system) but ppl mostly leave the 240 in as that tends to be ok!
Thanks, rgrds Adam! ____________________
Happy Days Kawasaki 04 ZX10R ... an animal! |
| lilredmachine |
 lilredmachine World Chat Champion
| CrazyPassenge... |
 Posted: 12:41 - 06 Feb 2006 Post subject: |
The last post was made 20 years, 137 days ago. Instead of replying here, would creating a new thread be more useful? |
