Why spend £175+ on new down pipes when you can do this.....
ian505050
PostPosted: 22:22 - 02 Feb 2013    Post subject: Why spend £175+ on new down pipes when you can do this..... Reply with quote
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2596_zps987608f4.jpg
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2604_zpsdb0001b7.jpg
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2597_zps540b475c.jpg
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2603_zps63380fb4.jpg
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2601_zps041a0263.jpg
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2606_zps4a36e2f9.jpg
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/IMAG2607_zps923a4fbd.jpg
Just spent some time and very little money on my bike. Decided that stainless steel down pipes are to posh for me and had a play with some gumgum and managed to blather it on the exhaust to fix a 10mm x 5mm holes (infact a few holes).
The stuff i used is ace, its like play-doe for men.
I nearly considered buying half a dozen tubs off the stuff and covering all the steel down pipes to prevent any more holes appearing.
My questions are
1) How long will my repair/modification/improvement last?
2.) Am i an Idiot?
ps. I am not a troll and a genuinely did this to my bike, it is not a photoshop
Clutchy
PostPosted: 22:25 - 02 Feb 2013    Post subject: Reply with quote
Did the same for a ped I had, depends on the vibrations in the road and how big any cracks/gaps are.
Sometimes mine lasted a day, sometimes a week.
You'll soon get bored of re-applying all the time.
However, I didn't see the condition it was in before, so may last last longer.
But to be fair, I used this stuff to partiality attach my exhaust to the manifold just to one broken stud and the other in half Laughing Laughing
2 litre
PostPosted: 22:26 - 02 Feb 2013    Post subject: Reply with quote
It will probably just blow out the first time it gets some high revs on it
ian505050
PostPosted: 22:27 - 02 Feb 2013    Post subject: Reply with quote
longer.
FFS i was think at least a few years
ian505050
PostPosted: 22:28 - 02 Feb 2013    Post subject: Reply with quote
Even if i apply a layer each day for a week? 7 layers should do the job
Clutchy
PostPosted: 22:29 - 02 Feb 2013    Post subject: Reply with quote
It will build up and then when it cooks the layers together, it will just come off in one go, did for me anyway.
Drake
PostPosted: 22:30 - 02 Feb 2013    Post subject: Reply with quote
seems you have been down lees road ehh just round the corner from my works
goto10
Use it in conjunction with an exhaust bandage, that will help keep it all on there.
Nope.
I doubt it, it will most likely just fracture between the layers.
If it were me and I wanted to bodge I'd wrap the pipe in baked bean tins, jubilee clip them on and then wrap then in exhaust bandage, on top of the gungum. That ought to hold you for a while.
Although I can't see why you wouldn't just get it welded...
Clutchy
PostPosted: 22:32 - 02 Feb 2013    Post subject: Reply with quote
THIS, THIS AND MORE THIS.
Except use a monster can.
ian505050
PostPosted: 22:36 - 02 Feb 2013    Post subject: Reply with quote
The holes right below the engine and impossible to weld and the down pipes cannot be removed.
I am tempted by the baked beans can method but will probably go for spaghetti hoops as you can get a can for 6p still at netto.
On second thoughts should i go for heinz as the can might be a bit better quality can?
polar
PostPosted: 22:38 - 02 Feb 2013    Post subject: Reply with quote
thats a god damn mess, get a new 1
Raffles
PostPosted: 22:40 - 02 Feb 2013    Post subject: Reply with quote
You could use it in conjunction with a wire mesh but even then it would just be a very short term bodge. Exhaust paste on it's Jack is next to useless.
mr jamez
PostPosted: 22:41 - 02 Feb 2013    Post subject: Reply with quote
You just lost £2.65 towards your new down pipes.
goto10
PostPosted: 22:44 - 02 Feb 2013    Post subject: Reply with quote
It's basically a 'get through the MOT' bodge.
Ja7
PostPosted: 22:45 - 02 Feb 2013    Post subject: Reply with quote
You've been reading paddys book again.
Cheeseybeaner
PostPosted: 22:50 - 02 Feb 2013    Post subject: Reply with quote
The downpipes cannot be removed? Why? Short-term exhaust bodges are just that, you'll be having to play with it over and over again. Much better to replace the downpipes with a nice stainless set that will never need touching again. Sandy's bike spares are cheap for this sort of thing, alternatively why not scour ebay for some good originals? What's the bike?
My bikes: 2003 KAWASAKI ZRX1200R, 1996 YAMAHA DIVERSION XJ900S
polar
PostPosted: 22:52 - 02 Feb 2013    Post subject: Reply with quote
if this was me i would have put the fairing back on the bike, and never told another soul, i definitely would not put them on bcf
you may as well cover the rest of the bike in the stuff. Laughing
ian505050
PostPosted: 22:55 - 02 Feb 2013    Post subject: Reply with quote
Downpipes can be removed because the exhaust studs will snap off Mad
polar
PostPosted: 23:01 - 02 Feb 2013    Post subject: Reply with quote
your right, they CAN be removed, go crazy with the wd 40 and maybe a little heat,, they will come out, and if they do snap, drill them and tap them, time to do a proper job.
ian505050
PostPosted: 23:16 - 02 Feb 2013    Post subject: Reply with quote
That would mean engine out to drill and tap properly, cant be arsed with all that sizzer me jizz
suzukirider19...
PostPosted: 00:17 - 03 Feb 2013    Post subject: Reply with quote
if you want it to last a while cover it with gum gum then wrap it tight with heat wrap and jubee clip it.
husky sm610
Seigi
PostPosted: 00:45 - 03 Feb 2013    Post subject: Reply with quote
You still have a Netto? Ours turned into an ASDA...
thx1138
PostPosted: 01:29 - 03 Feb 2013    Post subject: Reply with quote
Yeah I've bodged with gun gum a few times in the distant past, it's good for a while, but not long or medium term.
jeddy11
PostPosted: 10:59 - 03 Feb 2013    Post subject: Reply with quote
best to grind all the rust off first or it will continue to rust and that will break the gun gum also try heating it first before running the engine may give it a chance to harden properly.
But yer ive only used it on the cars years ago with limited success to be honest all these quick fixes for petrol tanks and radiators etc never last.. Thumbs Down
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
The last post was made 13 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.96 - MySQL Queries: 13 - Page Size: 129.21 Kb
